Sargent seat difficult to remove - Kawasaki Versys Forum
Like Tree3Likes
  • 2 Post By jaaklucas
  • 1 Post By Fly-Sig
post #1 of 3 (permalink) Old 05-17-2019, 10:07 AM Thread Starter
Doug Just Doug's Avatar
I've put a couple of thousand miles on my Sargent seat but it's still very difficult to unlatch. If I push down VERY hard in the right spot, it'll unlatch, but I can see how someone could break or bend the key trying to get it off. I've confirmed there's no interference with anything underneath (tool kit, Battery Tender leads, etc.). I've read that this is common with the Sargent seats for the Versys -- so has anyone found a solution? Shave down the rubber bumpers slightly? Shim the seat hook?
2015 Versys 650 ABS
AMA, Retreads Int'l.
Doug Just Doug is offline
post #2 of 3 (permalink) Old 05-17-2019, 11:15 AM
jaaklucas's Avatar
Ive got the Sargent seat as well. A little tight,scared me a bit at first as you dont want to force the key. You have to depress the seat as you turn the key. So I used some lithium grease in the latch and all contact points. And I cleaned the cable from the key lock to the latch with spray cable cleaner and gave the inside of the key lock a spray with WD. I thought of sanding the rubber bumpers a bit like you but working good after lube and cable cleaning. Alot better now. I love the seat, flat and perfect for me.
quexpress and Doug Just Doug like this.
jaaklucas is offline
post #3 of 3 (permalink) Old 05-17-2019, 11:52 AM
Fly-Sig's Avatar
I don't have any issues with my Sargent seat. 2015 V650. Slight manufacturing tolerances could be the culprit. If lubing doesn't work, I'd try shimming the latch a tiny bit.
Doug Just Doug likes this.
Fly-Sig is offline
Similar Threads
Using Swing-arm Stand on Lowered 650LT - difficult to raise & interference w/R Fender Wolfcamp General Discussions - V-650 13 02-13-2017 09:55 AM
Neutral difficult at times (Gearing issue) BKKPhil Technical Discussion - V-650 12 01-07-2015 01:04 PM
Sargent seat and overall seat height compared to stock basstodave General Discussions - V-650 2 06-22-2013 12:15 PM
How to remove the seat? Cruiseman Technical Discussion - V-650 6 05-27-2010 09:30 AM
Wanting sw motech side racks. How difficult is it to relocate rear turn signals? slowfaller Modifications - Cosmetic - V-650 31 09-20-2009 11:59 AM
