Home made Radiator screen - Kawasaki Versys Forum
Like Tree7Likes
  • 7 Post By 2linby
post #1 of 4 (permalink) Old 12-17-2017, 07:25 PM Thread Starter
2linby's Avatar
After pricing out radiator guards and being somewhat shocked at the pricing of these units I decided to search the web for ideas. Setting in on my first prototype I used 3/4" x 3/4" x 1/6" angle aluminum for the frame riveting it together and using some decorative stamped aluminum sheet I sourced on Amazon for the guard itself. One 5 foot stick of the angle did the trick. First time out on this so I really don't know how it'll hold up, but for less than $25.00 and something to do on a very cold rainy weekend I figured what the hell. This is on a 2014 Versys.
I started out measuring the outside of the radiator and figured 16.5 x 6.5 inches would give me the frame required to cover the entire radiator. I fabricated four brackets to fasten the unit to the bike. Two brackets made from the 3/4" angle stock and two made from some 1/2" x 1/8" flat aluminum stock on the top of the guard. 1/8" rivets with back up washers and the flat stock on the inside to give the screen some rigidity. To fasten the guard underneath I removed the two 5mmx 1.o (10mm head) bolts and used longer 25mm bolts then another nut and lock washer. For the top brackets I "field measured" and bent the flat stock at a 90 degree angle and riveted it to the guard and used a self tapping hex head screw I secured the brackets into the frame gussets on each side. Additionally I notched out on the right side of the guard (right as sitting on the bike) to allow room for the radiator cap and the lower hose connection. I also had to use a 30mm 5mm x 1.0 bolt and a 10mm long plastic spacer on the lower left side "fairing" to stand it away from the guard just enough to not place pressure on both. Hopefully the pictures show all this. I'll do a follow up review after I put some miles on the set up and may be paint it flat black. But for now it'll be as is.
ID:	139153   Click image for larger version
ID:	139161   Click image for larger version
ID:	139169   Click image for larger version
ID:	139177   Click image for larger version
COG# 5539
IBA# 15034
Team Oregon MC Instructor
"2linby" Get it? "Tooling by"
"Everything is simple, nothing is easy".
2linby is offline
post #2 of 4 (permalink) Old 12-18-2017, 01:11 AM
Looks great, good work sir! I too am a big fan of DIY mods on my bike.
post #3 of 4 (permalink) Old 12-23-2017, 11:48 AM
I dont think it has enough air flow for the hot summer days. let us know how often the fan goes off in the summer. Otherwise looks very cool !
I bought one from aliexpress for $15. link:
https://www.aliexpress.com/item/For-...311.0.0.xnkSIk
vaulter is offline
post #4 of 4 (permalink) Old 12-23-2017, 01:50 PM Thread Starter
2linby's Avatar
Yes I am aware of this potential. The Northwest rarely gets extremely hot and I rarely ride in city traffic for any extended period of time. But it is a potential concern that I am aware of. Thanks!
COG# 5539
IBA# 15034
2linby is offline
