ER-6N Oil Pan swap - Kawasaki Versys Forum
Like Tree6Likes
  • 4 Post By AlaskaJeff
  • 1 Post By fasteddiecopeman
  • 1 Post By AlaskaJeff
post #1 of 6 (permalink) Old 12-16-2017, 04:35 PM Thread Starter
ER-6N Oil Pan swap
Finished the swap-out of my OEM tall, with mounting lugs, and bottom drain oil pan to an ER-6N shorter, shaved side lugs, and side drain plug oil pan. I was having some clearance issues with my aftermarket slip-on springs and was getting ready to mount the SW Motech skid plate which necessitated the permanent removal of the lower side fairings, and since it didn't use the mounting lugs I figured I would shave them off as JDRocks did. I think it came out pretty well so far.
ID:	138593   Click image for larger version
ID:	138601   Click image for larger version
Name:	NewOil Pan5.jpeg.jpg
ID:	138609   Click image for larger version
ID:	138617   Click image for larger version
onewizard, quexpress, P.E. and 1 others like this.
post #2 of 6 (permalink) Old 12-17-2017, 12:02 PM
GREAT mod, Jeff.
AlaskaJeff likes this.
post #3 of 6 (permalink) Old 12-18-2017, 10:10 AM
kballowe's Avatar
Is the oil capacity changed ?
kballowe is offline
post #4 of 6 (permalink) Old 12-18-2017, 10:42 AM
KnobbyGuy's Avatar
2013 vs 2017 650's
For what its worth, my 2013 called for 2.5 qts (w/ filter change) and my 2017 calls for 1.9 qts!!
KnobbyGuy is offline
post #5 of 6 (permalink) Old 12-19-2017, 02:12 AM Thread Starter
As far as I could tell after the refill it's right at the same 2.5 with filter replacement.
kballowe likes this.
post #6 of 6 (permalink) Old 12-19-2017, 10:45 AM
FWIW - IF you have a Gen 1 or 2 w/ the oil-drain at the bottom of that long "tit", and DON'T have a skid-plate, suggest you be VERY CAREFUL riding anywhere 'rough', as IF you hit that, you're probably going to have a LONG walk (AND recovery of your Versys later!) ahead of you....
