Made my own tank protector for my 1st gen - Kawasaki Versys Forum
Like Tree12Likes
  • 11 Post By AJEI1973
  • 1 Post By Arion
post #1 of 8 (permalink) Old 11-04-2017, 04:32 PM Thread Starter
AJEI1973's Avatar
Not being at all happy with what was available, I decided to make my own.
I started by cutting open a gallon Ziploc bag and taping it to my tank. I then traced a rough outline of the shape and marked where I thought the cuts needed to be to get it to fit the curves correctly. I then scanned the bag and opened it in Inkscape. I traced the outline I and refined the shape and printed it on 11x17 paper. I then cut the shape out and test fit to the tank. After a couple rounds of tweaking the shape, printing, and cutting it out, I came up with what I thought would work.
I bought some VVIVID carbon fiber automotive wrap from Amazon and had a buddy cut it on a vinyl plotter.
After a little work with a blow dryer and a squeegee I am very happy with the results. It was very easy to install, and the wrap seems super tough.
LINKS TO FILES AT THE BOTTOM OF POST
Here are links to the PDF and svg files for anyone interested.
Click the links below to go to the public Dropbox and then click the download button in the upper right hand corner.
PDF file
SVG file
Green 2009 Versys 650
Last edited by AJEI1973; 11-05-2017 at 02:33 PM. Reason: Clarify download links for tank protector files
AJEI1973 is offline
post #2 of 8 (permalink) Old 11-04-2017, 09:34 PM
Nice piece of work and it seems to me worth the effort. Well done.
aboyandhisversys likes this.
post #3 of 8 (permalink) Old 11-04-2017, 10:34 PM
james75's Avatar
Looks great! Well done.
james75 is offline
post #4 of 8 (permalink) Old 11-05-2017, 11:41 AM
Well done. Hope you'll share your files.
post #5 of 8 (permalink) Old 11-05-2017, 02:33 PM Thread Starter
AJEI1973's Avatar
Links to the public Dropbox with the files are at the bottom of my original post.
I have edited it for clarity and with instructions for downloading the files.
Thanks to all for the kind words.
AJEI1973 is offline
post #6 of 8 (permalink) Old 11-06-2017, 12:13 PM
What Arion said....
post #7 of 8 (permalink) Old 11-16-2017, 07:51 AM
NightRider's Avatar
Nice work! Yours looks even better because it's not as thick as the usual stuff.
NightRider is offline
post #8 of 8 (permalink) Old 11-16-2017, 01:17 PM
looks good only issue i can see is if you leak some gas on it it might eat the adhesive away . if that happens DONT WIPE IT. heat it with a heat gun or blow drier and dab at it and the adhesive should re-harden
