Moto Werk 1" handlebar risers (2015+) install Q - Kawasaki Versys Forum
Like Tree6Likes
post #1 of 21 (permalink) Old 10-14-2017, 01:07 PM Thread Starter
So I ordered the 1" risers from Moto Werk.
I followed the install instructions but noticed something concerning the top clamp.
Should there be this much of a gap between the top clamp and the riser?
Thanks.
2017 Versys 650 LT -- Titanium [ Sold: Feb. 2019 ]
Debadged, Moto Werk lowering kit, slimmed down OEM seat, Shad SH33 top case, Scorpion Serket Taper exhaust, Moto Werk 1" risers, Grab On grip covers
407guy is offline
post #2 of 21 (permalink) Old 10-14-2017, 02:09 PM
Is that gap from AFTER you tightened the front bolts (to 'snug'), then finished by torquing the rear bolts to 18'/#?
(Looks to me that it is....)
post #3 of 21 (permalink) Old 10-14-2017, 06:36 PM Thread Starter
Yes, that is after tightening per the instructions.
407guy is offline
post #4 of 21 (permalink) Old 10-14-2017, 07:01 PM Thread Starter
Gap is in the front if I get the back part of the top clamp touching the riser.
407guy is offline
post #5 of 21 (permalink) Old 10-14-2017, 07:02 PM Thread Starter
So I "split the difference". The front and back have roughly the same gap between the top clamp and riser. (No picture.)
All torqued to 18 ft/lb.
https://cdn.shopify.com/s/files/1/11...57159767210442
407guy is offline
post #6 of 21 (permalink) Old 10-14-2017, 08:25 PM
The reason the instructions say to tighten the top bolts first is because the gap is suppose to be at the bottom. Same way on my 09 V-650 and my V-1000
P1010506 by weljo2001, on Flickr
407guy likes this.
post #7 of 21 (permalink) Old 10-14-2017, 09:36 PM
motorboy's Avatar
I think You have the top bridge on backwards-lay it on a flat surface you will see one side is flat on the table the other has the gap-no gap goes to the front of the bar- tighten the front two first than snug the rear two
Deep in Cajun Country
motorboy is offline
post #8 of 21 (permalink) Old 10-14-2017, 11:45 PM
Rebel13's Avatar
You can't install it backwards. Without the gap, you cannot tighten. If there is no gap, it will be loose! You are good as long as the tops are even and the bottoms are evenly gapped.
407guy likes this.
Rebel13 is offline
post #9 of 21 (permalink) Old 10-15-2017, 12:34 PM Thread Starter
Thank you guys.
Back to the way it was in my first post.
407guy is offline
post #10 of 21 (permalink) Old 10-15-2017, 10:30 PM
motorboy's Avatar
Service manual section 14-11 14-12
motorboy is offline
post #11 of 21 (permalink) Old 10-16-2017, 05:41 PM
The reason the instructions say to tighten the top bolts first is because the gap is suppose to be at the bottom. Same way on my 09 V-650 and my V-1000....
What Joe says.
ALSO - what motorboy said.
Manual says to have the FRONT snugged to NO GAP and the gap at the REAR when torqued to 18'/#.
407guy likes this.
post #12 of 21 (permalink) Old 10-16-2017, 05:42 PM
What Joe says.
...You are good as long as the tops are even and the bottoms are evenly gapped.
post #13 of 21 (permalink) Old 10-17-2017, 11:25 AM
Rebel13's Avatar
It really doesn't matter as long as it is tourqued and gapped evenly side to side. The reason the manual says that is so that you have a base alignment(a cheater) at all four points when aligning the first two instead of actually using a gauge for accuracy..
Rebel13 is offline
post #14 of 21 (permalink) Old 10-17-2017, 12:56 PM
I am glad this thread popped up as I am about to order the 1 inch risers. Two questions: 1) Weljo, did you have to do anything to carry you RAM ball mount over to use after the risers? Seems like it would require a longer bolt than supplied with risers? 2) Do you have to do anything with the cables with 1 inch risers? I know some other/higher risers require taking the cables out of the holders down near the shock tubes. I am the least mechanical here-what does it take to get the cables out of those loops? Fairing off or can you just reach down in there and set them free? Thanks for your help, and my back and hands will thank you if this is an easy mod.
cjcintucson is offline
post #15 of 21 (permalink) Old 10-17-2017, 02:07 PM
On my 650 this is all i needed...https://www.amazon.com/Mount-Motorcy...ram+ball+mount .Can't remember what length bolt i used but it was one of the three that came with the ball mount. On the 1000 I wanted the bolt to match the stainless Steel ones that came with the risers so i went to a hardware store and picked one up. Again i can't remember the length i had it written down but lost it. On the 650 and 1000 the cables were fine didn't have to do anything with them. Just put a towel on the tank so you won't get a paint chip in it like i did mine when dropped a socket wrench....
post #16 of 21 (permalink) Old 10-17-2017, 03:20 PM
Thanks Weljo. My 2011 came to me used with those RAM balls already mounted on the two upper bolt points. If the current bolts aren't long enough (probably won't be) I will just head to the hardware store. I plan to only use one ball for the present time on the riser install for my GPS.
weljo2001 likes this.
post #17 of 21 (permalink) Old 10-17-2017, 06:31 PM Thread Starter
Install should take less than 15 minutes.
And as written above, you do not need to do anything with the cables.
407guy is offline
post #18 of 21 (permalink) Old 10-17-2017, 10:30 PM
motorboy's Avatar
Nope-WE just went over this- the reason the manual says to do it that way is so the bars will not fall off-anyone on this site that thinks they are smarter than Kawasaki rise your hand if so you need to call Yoshinori Kanehana at 011-081-673-8666 and ask for a job
407guy likes this.
motorboy is offline
post #19 of 21 (permalink) Old 10-19-2017, 06:44 AM
Rebel13's Avatar
Um, yes! The service manual is just a factory guide! There is often more than one way to do things. Learning about engineering and punctuation helps!
Rebel13 is offline
post #20 of 21 (permalink) Old 10-19-2017, 10:13 AM
motorboy's Avatar
I'm at a lost for words over your last statement so I will not comment further-on my lack of punctuation to a layperson it would seem so-but I'm sure there are a few on this site that understand my style-hint- it's called no emotion reporting and I used it for so many years I have forgot all other ways
motorboy is offline
