V35 Lights from www.admorelighting.com - Kawasaki Versys Forum
post #1 of 41 (permalink) Old 11-01-2008, 07:08 PM Thread Starter
sharrison56's Avatar
I got my lights for the V35 cases. The installation was pretty easy. The instuctions are missing a couple of details but all of the important stuff is there. They provide nice connectors and a well made harness. They provide running, turn and brake lights. You will want to pickup some shrink tube before you start so that you can cover the short section of wire that isn't contained in the provided tubing. I soldered the wires because I hate crimp connectors.
Unfortunately lights don't photograph very well.
http://www.admorelighting.com/index.....php&subpage=9
Steve
Now I have four!
sharrison56 is offline
post #2 of 41 (permalink) Old 11-01-2008, 08:36 PM
DragonBreath's Avatar
Very nice Steve. I've been considering this upgrade as well. If you don't mind I'd like to see how you did the wiring when we meet up on Saturday.
Chris in Oneonta, NY
>>>> states on a bike <<<<
>>>> East Coast done <<<<
>>>>> Westward HO! <<<<<
DragonBreath is offline
post #3 of 41 (permalink) Old 11-01-2008, 08:44 PM Thread Starter
Thanks. I need to get some black shrink tube (all I had was blue), a little more wire and something to attach the wires to the inside of the cases. I might just get some black duct tape so the wires can't get caugt on anything. I will add some pictures of the connectors that go through the case tomorrow.
Steve
Now I have four!
post #4 of 41 (permalink) Old 11-02-2008, 06:37 PM Thread Starter
Here are some pictures of the wiring.
Steve
Now I have four!
post #5 of 41 (permalink) Old 11-03-2008, 07:44 AM
Ocean's Avatar
Nice - I've been looking at those. How hard is it to connect and reconnect the power cable and do the power cables just flop around when the cases are off?
Ocean is offline
post #6 of 41 (permalink) Old 11-03-2008, 08:01 AM Thread Starter
Look at this picture http://www.kawasakiversys.com/forums...9&d=1225668990 you just turn the little collar on the connector and they come right off. The cables that come off of the harness aren't real long and I was able to just use a black tie wrap to secure them to the frame. The wire is rigid enough that they don't really flop and the free end isn't really long enough to catch on anything.
I really like the tap connectors that they send with the kit. I am going to remove all of the scotch lock connectors and add my other lights to these connectors to clean up the wiring under the seat. I have also added another LED brake light to the back of the top case rack and the E52 LED brake light kit since the rack hides the brake light from anyone in a tall vehicle.
Steve
Now I have four!
post #7 of 41 (permalink) Old 11-04-2008, 08:49 PM
versysred's Avatar
Thanx for the photo's, Did you use duct tape on the interior of the case ? Is there any other securing options for the case interior ??
versysred is offline
post #8 of 41 (permalink) Old 11-04-2008, 09:12 PM Thread Starter
Not that I saw. The E52 that I have has a channel for the wiring.
Steve
Now I have four!
post #9 of 41 (permalink) Old 03-23-2009, 09:10 AM
mightymouse's Avatar
Howdy,
I just finished putting in the wiring into the saddlebags (thanks a lot for your pictures) and I'm curious - how did you run the wiring from the bike to the bags? Did you drill any holes, ? Would you mind posting a couple more pics to help a very challenged "mechanic" (I ride them I don't wrench them).
mightymouse is offline
post #10 of 41 (permalink) Old 03-23-2009, 10:17 AM Thread Starter
Are you talking about from under the seat to where I attached them to the racks? if that is it, I used the very tight opening down either side of the tail. I will try to get some pictures tonight.
Steve
Now I have four!
post #11 of 41 (permalink) Old 03-23-2009, 02:29 PM
That's exactly the area I was needing to see - did you drill holes at all? I'm waiting for word from Kawasaki to see if I'm going to void any warranty by doing the wiring myself.
Thanks in advance for your help on this
post #12 of 41 (permalink) Old 03-23-2009, 02:51 PM Thread Starter
The only holes were the ones in the cases for the connectors. There is plenty of room to run the wires around the sides of the tail...not much room for your fingers though. As for the wiring, you should have gotten screw on taps with the kit and all they do it punch a very small hole in the wiring insulation to provide the connection needed. They will not damage the wiring.
Steve
Now I have four!
post #13 of 41 (permalink) Old 03-23-2009, 11:17 PM
lokto7's Avatar
That kit costs $135 for intl customers... pretty expensive for the BOM...
lokto7 is offline
post #14 of 41 (permalink) Old 03-24-2009, 08:39 AM Thread Starter
The pictures I took last night didn't turn out too well, but the first two show how I routed the wires. The third one is where it comes out under the tail. It is pretty easy to get them through that opening, but it is a little easier if you take the red plastic pieces off.
Steve
Now I have four!
post #15 of 41 (permalink) Old 03-24-2009, 01:58 PM
Thanks for the pictures - I'll keep plugging away at it.
post #16 of 41 (permalink) Old 03-25-2009, 11:29 AM
gti20vturbo's Avatar
The LED ribbon is fairly cheap but the wiring harness that AddMore builds is top notch and makes the kit more than worth it. I put one of their kits in my topcase on my ST1300. I used the kit for the V35s but added more LED ribbon to make it even brighter. I cannot view it at work but I think this is the link to my setup.
www.youtube.com/watch?v=MARIuHkNSWM
ST1300, Versys, SV650S
gti20vturbo is offline
post #17 of 41 (permalink) Old 03-25-2009, 12:46 PM Thread Starter
Did you get the extra LED strips from them? How did you add them?
Steve
Now I have four!
post #18 of 41 (permalink) Old 03-25-2009, 08:09 PM
This is one place to get them. You just solder wires from one side of the existing ones to the new ones. There is a + side and a - side.
http://www.oznium.com/thin-led-strip
post #19 of 41 (permalink) Old 03-28-2009, 09:23 PM
Guest
If you decide to remove the cases is it easy to remove the wiring connection and reconnect at will ?
alienhost777 is offline
post #20 of 41 (permalink) Old 03-28-2009, 10:24 PM Thread Starter
Yes. Just twist the connector and it will come right off.
Steve
Now I have four!
