Speedy's GPS dash mount ideas - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 04-03-2012, 10:32 AM Thread Starter
Psalm11_6's Avatar
I've been combing through the threads here to see if I could find a few ideas of how people used the flat plate GPS dash from Speedy:
Speedy's Mount
Having a hard time coming up with any output though. I'm thinking about drilling in a RAM mount for the GPS and a couple marine power sockets at this point, perhaps throw in a datel voltmeter, but I'm still not sure... I'd likely build a cover for the back of the setup to hide the wiring, of course. Also, I'm not sure how much room is available behind it to throw in those sockets, so there's a potential of just sticking the things in the plastic (though I am not very happy with that idea at this point!)
Any one else that's had some experience modifying this mount? I appreciate any feedback/pics!
2008 Versys - 37k miles
Givi - V35 Monokey Saddlebags - Large windscreen - Tail rack with v46 trunk
Speedy's - 1" Handlebar risers - Footpeg Lowering blocks
Osram 65W Bright replacements
Kawasaki Handguards
... And the all important gremlin bell, courtesy of my wife.
Psalm11_6 is offline
post #2 of 8 (permalink) Old 04-03-2012, 01:15 PM
Expect ABOUT 3/4" to the OEM windshield at the top, 2 3/4" at the bottom.
post #3 of 8 (permalink) Old 04-03-2012, 06:29 PM
Baron650's Avatar
I have a Nuvi 550 in a Garmin mount secured to Speedy's plate-
Power for the GPS (hardwired to acces. panel) comes through the dash at bottom right. Great location for GPS, but too exposed for plugs etc. IMO.
Lots of room on the dash to either side of the guages to put in a power port or grip heat control, and the wiring all can be easily hidden away.
Baron650 is offline
post #4 of 8 (permalink) Old 04-03-2012, 06:44 PM
A2RON's Avatar
Speedy Mount with RAM mount base with GPS (lower) and smartphone (upper) mounts. GPS power is a dedicated line, the smartphone is a USB powerport. Originally I wanted to mount the USB port behind the Speedy plate......there was enough room for the port, not enough room for the cable-so I cable tied the port to the leg of the Speedy Mount.
Riders view and side view:
A2ron
Charleston, SC
A2RON is offline
post #5 of 8 (permalink) Old 04-03-2012, 07:18 PM Thread Starter
Psalm11_6's Avatar
Holy crap that setup looks intense! And probably about the closest to what I was wanting to do actually :-D
Quick question on those power connections as I'm an LD noob: water proof?
Kawasaki Handguards
post #6 of 8 (permalink) Old 04-05-2012, 07:01 AM
A2RON's Avatar
The powersupply for the Garmin is more or less weatherproof ( http://www.kawasakiversys.com/forums...ead.php?t=5571 ) but the GPS itself (now a Nuvi 1450) and its connector are not.
I have a weather resistant PDA bag (Bag Connections from Twisted Throttle) that I use if I'm sure of hitting a lot of rain, I remove the whole assembly and just use the GPS with the bag.
Otherwise, if I'm just caught out in a shower or I want to run the cammera on my smartphone, I use a clear dry bag that slips over the smartphone cradle and GPS that still allows me to shoot pictures and videos.
Like the GPS powersupply, the smartphone is running off a 12V-5V USB "weatherproof" powersupply that is weatherprooof up to the connector that plugs into the cradle/phone-neither of which is water resistant.
This is the 12V/5V USB unit available for many vendors, I got mine here http://burnsmoto.com/usb-power-socket-weatherproof.php
If you want to use the USB powersupply to run a Garmin GPS, you need a special USB charge only cable, normal USB cables will put the GPS into mass-storage mode and make the GPS think its connected to a computer.
I'm experimenting with 3 different sizes of clear weatherproof mapcases to reduce the bulk of the drybag and have a flatter surface on the face and camera side. Might end up cutting one down to get the best fit.
When parked outside, I use a small black drysack to cover the whole assembly -keeps it dust and waterfree and is out-of-sight-out-of-mind to passerby's.
After 40,000 miles I haven't lost a GPS yet.
A2ron
Charleston, SC
A2RON is offline
post #7 of 8 (permalink) Old 04-05-2012, 08:03 AM Thread Starter
Psalm11_6's Avatar
Thanks for the info! Im looking at a nuvi 550 for this go round.
I appreciate the response. I've got some ram research to do to get the right dual mount.
Kawasaki Handguards
post #8 of 8 (permalink) Old 04-05-2012, 01:40 PM
Originally Posted by Psalm11_6 View Post
Thanks for the info! Im looking at a nuvi 550 for this go round....
I have TWO! Good little units.
