SW-Motech crash bar install problem - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 01-01-2012, 02:01 PM Thread Starter
Man, nothing but problems this weekend. I'm installing the SW-Motech crash bars on my 2011. I've got everything in except the left side u-bolt. The bars don't seem to line up with the frame correctly, and I can't get the bolt into both holes. The U has to angle downward into the holes, and the bottom part won't even go in far enough to get the nut on the end of it. The right side U-bolt went in nearly horizontal, but the left side is way off. Have I got a defective bar, or am I missing something here? Also, what is the purpose of the U-bolt? Is it vital to have this secured, or is it just to keep the bars from vibrating against the frame? If I don't get this figured out today, I'd rather not have to completely undo everything I did, but I also don't want to be riding around if that piece absolutely needs to be secured..
TwoTacoCombo is offline
post #2 of 5 (permalink) Old 01-01-2012, 02:11 PM
Did you just put the bolts in loosley or did you tighten everything as you went.?
post #3 of 5 (permalink) Old 01-01-2012, 02:52 PM Thread Starter
Tightened the two front mounts first, then the rear mount, right U-bolt, then left U-bolt. I tried backing out the front left bolt, but that didn't give me much play. It doesn't seem like a matter of wiggle room. The mounting points aren't loose enough to give much leeway, and the left U-bolt mount is way off. I did manage to put enough pressure on the bar to get the nuts on the bolt now, but it's putting a lot of pressure on the top of the frame bar, and it just doesn't look right...
post #4 of 5 (permalink) Old 01-01-2012, 08:20 PM
sambamboo's Avatar
I had the same issue with mine i ended up using a small round file and taking a little bit out of the upper edge of the holes so the U-bolt could slip into them.. i dont have them tourqued up super tight just enough that they dont move.
sambamboo is offline
post #5 of 5 (permalink) Old 01-01-2012, 09:04 PM
Jeff S's Avatar
I just got a set of these, and had a similar issue, also on the left side. Sounds like a small manufacturing defect. But, mine seems to have been less severe than yours. I was able to thread the lower nut on a couple turns by hand, then ratcheted it down a bit. That pulled the U around lower, and the top of the U then lined up well.
Jeff S is offline
