H&B crash bars? - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 10-09-2008, 11:46 PM Thread Starter
H&B crash bars?
I am installing the H&B crash bars and would like to know what should the two main bolts be tightened to? The two that go into the engine mount. I would assume to 32 ft lbs. as would the regular bolts that came out. But I did not see any info in the instructions. Any help would be appreciated.
JERRYES is offline
post #2 of 3 (permalink) Old 10-10-2008, 01:56 AM
Yes, 32 ft-lbs as specified for the stock bolts... You could shim it out on both sides while the bolts are out, if you haven't already:
http://www.kawasakiversys.com/forums...ht=frame+crack
post #3 of 3 (permalink) Old 10-10-2008, 07:26 PM Thread Starter
Thanks for the info I did not do that while I had it apart but I will do it soon. It needs to be done as there is a gap on both sides. Thanks again.
JERRYES is offline
Similar Threads
Crash bars - HB or SWmotech RedRabbit General Discussions - V-650 61 02-05-2011 09:53 PM
HEPCO and BECKER Crash Bars are in the US PO-SLOKE Modifications - Cosmetic - V-650 49 04-19-2009 04:20 PM
Two Up Survive Brp Crash PO-SLOKE Member Rides 11 09-06-2008 06:06 PM
Motech Crash Bars lost84001 Modifications - Performance - V-650 9 07-26-2008 07:49 PM
Handle bars motorbum Modifications - Cosmetic - V-650 1 07-22-2008 12:09 AM
