Magic Blinkers installed - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 10-01-2011, 06:34 PM Thread Starter
Velocibiker's Avatar
Front and rear signals are now 100% on as running lights and blink 'off' when signal is activated.
Front signals were a little ornery, but the rear ones were really easy since all the wiring is right there under the seat.
Will need to replace the signal relay with an electronic one as the signals blink a little too fast.
Magic Blinkers
To save a few watts, I replaced the license plate light and city lights with LEDs. Thinking of going with a yellow low beam to make the bike stand out more since there are a lot of cars now with DRLs and I think bikes don't stand out as much as they used to.
Velocibiker is offline
post #2 of 10 (permalink) Old 10-01-2011, 09:28 PM
blipco's Avatar
Does your signal indicator on the dash stay ON while riding and blink while indicating a turn?
blipco is offline
post #3 of 10 (permalink) Old 10-02-2011, 11:00 AM Thread Starter
Good question, but no. Dash light work as normal. The magic blinkers are simply an electronic version of a standard 12v relay.
post #4 of 10 (permalink) Old 10-02-2011, 10:54 PM
Down here all big CC bike run with Running light and are wired to the blinkers.
Picture shown with blinkers as running lights..
post #5 of 10 (permalink) Old 10-03-2011, 01:54 PM Thread Starter
Damn. That means I could have done it with a simple(?) wiring change. I didn't even think to look at the non-U.S. wiring diagram to see if it was different. Oh well, it's done now and works great. All bikes should be this way to start with.
post #6 of 10 (permalink) Old 10-03-2011, 10:27 PM
2daMax's Avatar
The DRL for bikes needs a special blinker/running light relay. Unfortunately, this relay makes LED blinks fast. You would still need a LED blinker relay to replace the stock relay.
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #7 of 10 (permalink) Old 10-03-2011, 11:09 PM
This is the unit we use here for Running/Blinker light.
post #8 of 10 (permalink) Old 10-04-2011, 07:23 PM Thread Starter
Ok. Not so simple. I like my solution better.
post #9 of 10 (permalink) Old 10-05-2011, 12:03 AM
mikej's Avatar
For this could you have added a new fused relay. disconnected the blinker relay output and reconnected that to normally closed on new relay. Turn signals now lit full time. Then use the turn signal blinker output to turn on the new relay so that it disconnects the power to turn signals. one wiring change under seat to fix them all.
mikej is offline
post #10 of 10 (permalink) Old 10-05-2011, 11:10 AM Thread Starter
That's what I did on my DR650, but you need a relay for every signal, just like the magic blinker is needed per signal. Just one relay won't work.
