Twinshack Hugger & Ermax Undertail & Cherry Bomb - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 10-04-2008, 09:17 PM Thread Starter
Hi Folks,
Just a few pics of my farkling efforts.
cvienna is offline
post #2 of 5 (permalink) Old 10-05-2008, 07:15 AM
Ocean's Avatar
Nice and tidy, I really like the effect.
Ocean is offline
post #3 of 5 (permalink) Old 10-08-2008, 06:37 AM
cvienna ,
Any chance you could post some links for these products and maybe mention level of difficulty of installation .... etc... etc ....
Thanks in advance , Wes
PO-SLOKE is offline
post #4 of 5 (permalink) Old 10-08-2008, 09:51 AM
myorangecamaro's Avatar
next on my list........................ looks awsome!
myorangecamaro is offline
post #5 of 5 (permalink) Old 10-08-2008, 11:54 PM Thread Starter
Got the hugger from Twinshack in England
http://www.twinshack.co.uk/prods/126.html
I believe it is the same as the one made / offered by Poly26 in France.
Painted it myself ( got a colour match done on the paint and a spray can made up). I am not very skilled at painting. It turned out ok.
Very easy to install. Would definately recommend lock-tite on the bolts as I lost the 2 orginals whilst riding. ( you will need on extra M6 bolt)
Got the Ermax undertail from an Motorcycle Parts importer in Quebec.
http://www.csmeca.a3w.net/DetailElem...Rubrique=47178
This one had to be painted as well. Went with an industrial grade flate black topped off with a clear reflective coating spray.
This one was a PIA as the signal light needed to be mounted ( ie., holes drilled through the plastic and position in place).
Also, I could not find the connectors for the wiring and I did not want to cut the stock connectors so I crimped and soldered some pin and spade connectors. Had to reverse the wiring after the first attempt because the LEDs will only work when wired properly (++, --, I think?)
Also, had to bend the license plate mount. I managed to screw this up (it is angled a little, thankfully not notiecable). The license plate mounting holes did not line up with the holes on my plate ( I did try the mounting bracket from the stock fender, but pushed the plate in front of the plate light), so I drilled a couple of new holes in my license plate.
All said and done, I am satisfied with the look of bike.
I picked up the Cherry Bomb muffler from NAPA Autoparts they got it from Zoro Muffler and got the connecting adapter pipe from Canadian Tire (like a PEP Boys). I struggled with Muffler tip. I tried to have one custom made but it was too much back and forth to the muffler shop, so I orderd a tip ffrom Versys08 on the forum. This job was not that easy for me. I lost the custom tip a couple of time and the muffler separated from the header once. I did finally get all secure and have put on about 3000 KM without any problems with the muffler set up. I do love the sound of the bike now. I am still seriously considering going to the Arrow Exhaust System.
I now understand why it is called farkling.
Cheers,
Colin
cvienna is offline
Similar Threads
Electrical LED Help Please - Ermax Undertail install in progress cvienna Technical Discussion - V-650 7 10-04-2008 10:23 PM
Hugger, again! novice Modifications - Cosmetic - V-650 6 09-01-2008 03:53 PM
***warning***cherry Bomb Problem*** Hooligan General Discussions - V-650 30 07-21-2008 04:40 PM
