Another Power Outlet Install - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 09-11-2011, 10:17 PM Thread Starter
Took the time to read a lot of the installs and advice on here regarding power outlets, here is my experience:
1. Took the left side fairing off, thinking that a) I could install a power outlet like Cap'n Kirk and b) use the OEM harness plug like 2daMax. However, I had a different sensor set up on my '09 - it was larger and took up most of the space where Cap'n Kirk put his outlet and I could not find any extra OEM harness wires anywhere.
For now, I did not want to cut a hole in the dash or fairings, so I went for an install under the seat.
I used the weatherproof outlet from O-Reilly's. Rather than mount the outlet permanently under the seat, I left about 5 feet of wiring so I would have options to move the plug into my tank bag or put it sidebags if I get any later on...
Basic details - wired hot to the battery, put in an in-line fuse AND an in-line on/off switch (SPST) with an LED light. The reason for this was I wanted to be able control power to the outlet. Also, I wanted to be able to use this outlet in the winter time for a battery minder, so direct wiring made more sense.
Here is a picture where you can see the wiring off the battery, the inline fuse holder (upper right corner) the switch (installed in an oblong OEM hole in the frame cross member - I had to slightly widen the hole with a dremel), the ground for the switch LED light and the power outlet (obscured by the U-lock strap, but there is an OEM bolt under there that provides a good ground) and the entire wiring and the socket securely fastened under the u-lock strap:
I need to come up with a better way to keep the extra wiring in check. The zip ties work well until I need extra length...
For my cell phone, I can either plug it in and throw it under the seat (phone and GPS worked fine charging up under the seat of my buddy's Ulysses yesterday), or I can plug in a longer cord and snake the wiring up the front of the seat to the tank bag:
I'll probably go a more permanent route in the future, but at least I can keep my cellphone (and GPS/Music) charged on rides
ID:	12562   Click image for larger version
Jmason is offline
post #2 of 8 (permalink) Old 09-11-2011, 10:47 PM
I have both of these. one on the left side one on the right. hooks right to the battery easy as pie.
http://www.powerlet.com/product/ciga...uty-10-amp/383
IMG_0067 by weljo2001, on Flickr
IMG_0068 by weljo2001, on Flickr
post #3 of 8 (permalink) Old 09-14-2011, 01:06 AM
2daMax's Avatar
Great work on wiring it up. The wiring harness for 12V outlet is only available for the 2010/11 V, unfortunately.
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #4 of 8 (permalink) Old 06-07-2012, 11:18 PM
Put an outlet behind the headlight to power the video camera or anything else thats needed.
IMG_1479 by weljo2001, on Flickr
post #5 of 8 (permalink) Old 06-08-2012, 12:02 AM
Motopsycho's Avatar
Personally I think it looks a little cluttered under the seat, but whatever works for you. Here's what I did
IBA # 49372
Motopsycho is offline
post #6 of 8 (permalink) Old 06-08-2012, 08:03 AM
genehil's Avatar
My Setup for the long hauls:
I've got a Cap'n Kirk 12V setup. Into that I plug a 12V splitter (with wx caps) and into one of those, I plug in a dual USB adapter. The splitter wires are long enough to run into my tank bag... either one or both... through a gap between zipper pulls.
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #7 of 8 (permalink) Old 06-08-2012, 02:53 PM
x
AzItLies is offline
post #8 of 8 (permalink) Old 06-08-2012, 05:41 PM
hdatontodo's Avatar
If you have a battery tender charging cable zip-tied to the frame, you can wire up a plug for it with a 12v female outlet on the other end.
Tony
2002 Honda Goldwing
IBA #24737
(daytime)
hdatontodo is offline
