mirrors - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 08-01-2011, 05:47 PM Thread Starter
Que
Que's Avatar
mirrors
I've had a problem with my mirrors moving counter clockwise while I ride. I want to know if there is a way to tighten it up a bit so it doesn't move. If anyone has any pics of how to get it done it would be greatly appreciated.
Que is offline
post #2 of 12 (permalink) Old 08-01-2011, 08:21 PM
WannaRideVersys's Avatar
On my '09 it goes like this: Remove the rubber boot, unscrew the top mounting nut from the bottom one. Inside of the top nut/housing, there is an 8mm nut attached to the mirror stem. Screw all of this back together without torquing down, get the stem lined up where you want it to stay, then remove the assembly and tighten the 8mm nut inside the upper housing.
Good luck!
'09 Greener
Ride on. Ride hard. Respect the bike.
WannaRideVersys is offline
post #3 of 12 (permalink) Old 08-01-2011, 10:52 PM
emdavis197's Avatar
I hated my stock mirrors so just for giggles I tried some very cheap eBay specials: http://cgi.ebay.com/ebaymotors/MIRRO...Q5fAccessories
Believe it or not, they are 10X better than the stockers, both in the ease in which they secure and completely eliminate the rotation problem, and also for vibrations. They are not "vibe free" but are noticeably more clear than the stock mirrors at 60 - 70 mph.
But if you are trying to solve the rotation issue on the stockers, I agree with the above post, but I would also add using blue locktite on the inner nut and washers (inside the top nut housing), and on the large mounting nut threads under the rubber boot.
Eric
2009 Kawasaki Versys - Candy Plasma Blue
2013 Yamaha WR250R
emdavis197 is offline
post #4 of 12 (permalink) Old 08-01-2011, 11:35 PM
Pismocycleguy's Avatar
Thumbs up
Nice looking mirrors, and a great price!
“Don’t bother me with DETAILS!”
Pismocycleguy is offline
post #5 of 12 (permalink) Old 08-02-2011, 11:24 AM
buffamazon's Avatar
Send a message via Yahoo to buffamazon
The stockers on the 09 are notoriously crappy. Especially the left one. Just buy new mirrors now as you WILL continue to have problems with them..lol
09 Versys In Go-Fast Green
Acerbis Pro Pack Handguards
Ogio Tailbag
Ogio Saddlebags
Vortex 44T Sprocket
Wolo Bad Boy Air horn
Trackside 12 volt power adaptor
buffamazon is offline
post #6 of 12 (permalink) Old 08-02-2011, 03:31 PM
outdoorvtguy's Avatar
I just stopped by my local ( Aprilia ) dealer and they were surprised to find that Aprilia Tuono mirrors ( 2006-2009 ) were only about $20 a piece. I ordered a set to try, the CRG's work OK but I have to look down to see behind, might be better to have them higher. I looked at some on a Tuono that was being serviced and they are wider ( i.e. no extenders needed ) and appear LOWER than the stock. Just what I wanted...
outdoorvtguy is offline
post #7 of 12 (permalink) Old 08-03-2011, 12:20 AM
Pictures Please
Fastoman is online now
post #8 of 12 (permalink) Old 08-03-2011, 10:23 AM
Ralpheal316's Avatar
i bought these mirrors minutes ago on Amazon the link is below my OEM mirrors suck
constant moving life hazzard.....
Ralpheal316 is offline
post #9 of 12 (permalink) Old 08-03-2011, 12:10 PM
They had to order, when I get them I will post pictures....
post #10 of 12 (permalink) Old 08-03-2011, 05:57 PM
Stazjemo's Avatar
Here are the Aprilia mirrors. Mine came in about 2 weeks ago, they're great!
I have my small spot mirrors on too.
Vulcan 1700 Classic
Stazjemo is offline
post #11 of 12 (permalink) Old 08-03-2011, 09:48 PM Thread Starter
Que
Que's Avatar
Thanks for the help ...finally got it done. They now hold and I don't have to constantly adjust them while i ride. I have to say it was harder then I thought to get access to that small bolt inside. fyi it was 10mm inside. I think i will try it out another week or so and see if I need to put some locktight on it.
Que is offline
post #12 of 12 (permalink) Old 08-04-2011, 03:30 PM
buffamazon's Avatar
Good luck que. Mine would get snugged up, then over time they always came loose again. Nothing like a floppy mirror while you are hauling a$$ down the freeway
Ogio Tailbag
Ogio Saddlebags
Vortex 44T Sprocket
