How can I wire a 12v outlet to my Versys? - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 09-29-2008, 09:37 PM Thread Starter
How do I wire a 12v outlet to my Versys?
ovidgsd is offline
post #2 of 10 (permalink) Old 09-30-2008, 06:53 AM
dallasdon's Avatar
Here's is how I did mine. You can actually put one on either side of the dash panel if you want to. There is enough room. I also included a fuse block link that I did to run the power to the power outlet.
Power outlet thread:
http://www.kawasakiversys.com/forums...t=power+outlet
Fuse block thread:
http://www.kawasakiversys.com/forums...ght=fuse+block
'09 Versys -Green
TET'68 Survivor
dallasdon is offline
post #3 of 10 (permalink) Old 09-30-2008, 08:18 AM
Ocean's Avatar
I did the same thing - added a power panel by Centech. You can see the pics here: http://www.kawasakiversys.com/forums...hlight=centech
For my taste, I like the dash the way it is and decided to add the power outlet to the side of the bike instead using parts form Powerlet http://www.powerletproducts.com/
Ocean is offline
post #4 of 10 (permalink) Old 09-30-2008, 10:19 AM
Wordguy's Avatar
Where on the side of the bike did you add your power outlet? I want to add one for my heated clothing, so I'd like to avoid having to plug in on the dash.
-Alan
Wordguy is offline
post #5 of 10 (permalink) Old 09-30-2008, 11:40 AM
Ocean's Avatar
I haven't done it yet - the farkle fund is being built up for the heated gear. Here's an image from Powerlet with the kit mounted on the side of the bike. http://www.powerletproducts.com/prod...-kit-black/161
I was going to make this the next purchase but then I decided to go with the TourMaster heated liner - that liner comes with the heatroller and the wiring. I'll just tap that directly into my power panel. The other heatroller and liner setups required a power outlet. Since I'd rather be warm and comfy this fall season - I'll save the money for the heated gear and hold off for a bit on the power outlet.
Ocean is offline
post #6 of 10 (permalink) Old 09-30-2008, 02:39 PM
Wordguy's Avatar
That looks pretty nice. I already have the socket because I was going to install one on my previous bike. I saw a picture someplace of an outlet in the lower edge of the front fairing... I can't find the picture now.
-Alan
Wordguy is offline
post #7 of 10 (permalink) Old 09-30-2008, 03:14 PM
I bought a weatherproof 12v outlet and an inline fuse from auto parts store for about $15 and wired it under the seat into the tail light harness so it operates when the key is on. My vest and GPS cords can run under the front of the seat and the plug is out of sight and harms way. Works like a charm.
Gatorman is offline
post #8 of 10 (permalink) Old 09-30-2008, 03:17 PM
DragonBreath's Avatar
Alan,
I bet this post is the one you are looking for.
I have a 12V in that same spot, but the one that I used is a bit tall. Once I plugged my GPS cord into it, I realized that the handlebars hit the back of the plug. I have ordered and will be installing a low profile marine plug like that shown in the link above.
The Powerlet products are awesome, but it gets pretty pricey to plan for every eventuality with adapters and such. Sure wish I could go that route, but it's not worth it for me.
Chris in Oneonta, NY
>>>> states on a bike <<<<
>>>> East Coast done <<<<
>>>>> Westward HO! <<<<<
DragonBreath is offline
post #9 of 10 (permalink) Old 10-11-2008, 08:03 AM
Here is a photo of my 2 12V outlets.
Ted99uk
File Type: jpg 2 12V sockets+Voltmeter+GPS RAM cradle.JPG (134.6 KB, 309 views)
Ted99uk is offline
post #10 of 10 (permalink) Old 10-12-2008, 11:34 AM
dallasdon's Avatar
Ted99uk
That looks very nice and functional. Thanks for the post.
'09 Versys -Green
TET'68 Survivor
Similar Threads
12 Volt Power Outlet [email protected] Modifications - Cosmetic - V-650 11 07-24-2010 07:05 PM
Power Outlet dallasdon Modifications - Cosmetic - V-650 8 08-21-2008 06:31 PM
Relay Wire? Slaying Mantis Technical Discussion - V-650 5 07-29-2008 02:13 PM
Versys Tach Wire wngrr Technical Discussion - V-650 0 06-21-2008 03:33 PM
