Hepco/Becker engine guard vibration - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 09-19-2008, 10:48 PM Thread Starter
Guest
Is it just me or are there others that noticed more vibration since they added their Hepco and Becker engine bars?
Today while riding I put my left hand on the frame and it didn't have vibration, but when I put my hand on the bar I could feel the vibration. That vibration transfers back to me.
I tightened the two large engine bolts first, then the rear ones and then the cross bar, so there is no stress to the bars and all the screws are tight. I'll need to try some things to cut the vibration feel.
atgatt is offline
post #2 of 13 (permalink) Old 09-20-2008, 01:34 AM
I'm sure it vibrates with the rest of the bike, but i really didn't notice a difference after installing the bars.
Gustavo
Gustavo is offline
post #3 of 13 (permalink) Old 09-20-2008, 08:47 AM Thread Starter
Guest
Gustavo
That's the problem, it does not vibrate like the rest of the bike. The frame had no vibes but the bars did. I'll try playing with the bar screws today.
atgatt is offline
post #4 of 13 (permalink) Old 09-21-2008, 08:54 PM Thread Starter
Guest
I'll answer my own post. Today I slightly loosened the rear screws, nearest the legs, on the Hepco bars. That alone really cut the vibration. Before that at 6000 rpm it really vibrated but now it is about normal.
atgatt is offline
post #5 of 13 (permalink) Old 08-28-2009, 09:49 AM
Noticed the same thing
Atgatt, I installed my HB bars yesterday and immediately noticed exactly what you described but it was primarily in the range of 2500 to 4000 rpm.
Building on your suggestion, I cut some heavy rubber fuel hose to take the place of the metal spacers used in the rear (bike center) HB mount. Definitely helped but it still feels more vibey than before the HB bars.
During install, I noticed the gap between motor-mount and frame tab and threw some washers in there. I've read this morning that others (Gustavo included) may think that these are unneeded and may even cause some vibes. Indeed, I did do each motor mount one side at a time so may have seen an artificially large gap between mount and frame tab.
I'll try removing those spacing washers today and let you know what shakes.
Oh, and I really like the look of the bars but, damn, are these things heavy! I could use them for doing curls...but I do have pretty skinny arms!
bkarger is offline
post #6 of 13 (permalink) Old 08-28-2009, 10:19 AM Thread Starter
Guest
bkarger, that is an old post and since then I put the bars as close to their spacers as I could naturally get them with the screws loose and then tightened.
The right bar went right up against the metal spacer nearest the seat, but the left bar left a decent gap. For that I added a rubber spacer so the right bar wouldn't flex in when I tightened that screw. That really cut down on the vibes, but like so many others, that left support screw shears and I've replaced it twice but no more. Now I just leave in their broke and I've added strong tie-wraps that go around the HB bars and frame bars on each sided where the HB bars come closest to the frame. So basically the tie-wraps are pulling in the back of the HB bars near the support screws. There is no added vibration now except for the normal vibration.
It has been a while since I put them on, but the bars did not hit me as being heavy considering. I think the bars look good and are functional too. MUCH better than the sliders I had on before.
atgatt is offline
post #7 of 13 (permalink) Old 08-28-2009, 10:22 AM
sharrison56's Avatar
The main thing is they really do work. My bike has been down a few times for various reasons (not all my fault) and there has been no damage to the bike...just some scratches on the bars. For what they are intended to do they work great. I didn't notice any additional vibes, but that just means that I didn't notice them. They could be worse.
Steve
Now I have four!
sharrison56 is offline
post #8 of 13 (permalink) Old 08-28-2009, 11:02 AM
You guys are fast! I appreciate the update and protection reports. I didn't know about the bolts shearing so I'll have to look that up.
I may also remove the washers I added in the engine mount area to see if that gets the vibes back to before-the-HB levels.
Thanks.
bkarger is offline
post #9 of 13 (permalink) Old 08-28-2009, 09:25 PM
I have not notice any increase in vibration since adding HB crash bars.
I didn't add any spacers to my motor mount gaps. Simply bolted everything back together.
DK35vince is offline
post #10 of 13 (permalink) Old 08-28-2009, 10:16 PM
I installed my HB crash bars about two weeks ago and I can feel more vibrations in the seat and foot pegs. But I'm getting used to it.
Dave
55wed55 is offline
post #11 of 13 (permalink) Old 02-08-2011, 03:46 AM
Hello everyone
I've installed the HB guards on my Aprilia Pegaso Strada. The guard vibrates wheh I rev up the engine. Later found out that one the the weld points is broken. Still waiting for my 2011 Versys...
KlVersys
kuala Lumpur
Malaysia
KlVersys is offline
post #12 of 13 (permalink) Old 02-08-2011, 09:28 AM
Originally Posted by KlVersys View Post
Hello everyone
KlVersys
kuala Lumpur
Malaysia
Bro and nice to see you here.
Vib is normal on a parallel twin. Worst engine configuration and we all have lived with it.
I feel and see the vib on warm up phase after that it's normal.
Fastoman is online now
post #13 of 13 (permalink) Old 02-11-2011, 01:31 PM
Ted
The HB bars are great protection. But I also had to add rubber washers at the back screws to reduce vibes. Also add a check of those screws to your normal pre-ride. Even with lock tight I have had them become loose. Then you really will feel vibes when you ride.
Ted is offline
Similar Threads
Hepco Becker engine guard installed under Modifications - Cosmetic - V-650 46 08-31-2010 03:40 PM
Hepco Becker Bars are handy for driving Lights and Highway Pegs! 2xadv Modifications - Cosmetic - V-650 28 04-24-2009 05:52 PM
HEPCO and BECKER Crash Bars are in the US PO-SLOKE Modifications - Cosmetic - V-650 49 04-19-2009 04:20 PM
Best Engine guard? johnnail Modifications - Cosmetic - V-650 15 10-23-2008 10:09 AM
Hepco Becker Gobi 37L ttudesperado General Discussions - V-650 7 09-15-2008 12:13 PM
