My $5.00 radiator rock guard!! - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 09-15-2008, 11:42 AM Thread Starter
been wanting a radiator rock guard for my V....but i didn't like the flashy expensive ones out there....and if you know me....i like to do it cheap and easier at home.......went to Lowe's home improvement...bought a piece of 36" plastic gutter guard (brown) for $1.98....cut the joint connecting ends off..trimmned it to the length of the radiator(including the water tanks) ...then i took two pieces of 1 inch wide aluminum i had laying around, pop riveted them to each end, painted the whole thing flat black, i used waterproof VELCRO on the aluminum ends to stick it to the tanks.....added a few little pieces of foam ot keep it from bouncing around , and finished it off with few nylon zip ties for good measure.....should flow plenty of air as it sits off the grill completely, peels right off if i need to, and should block all but the biggest of rocks! In case your wondering if the velcro will hold it...YEP.. i used the same stuff to attach my FENDA EXTENDA......didn't want to drill holes in the plastics....it's not going anywhwere!!! tell me what you guys think.......
tsunamichop007 is offline
post #2 of 12 (permalink) Old 09-15-2008, 11:46 AM Thread Starter
forgot to show a pic of the fenda extenda....i used vercro to attatch it also, used a 2 inch wide strip from side to side.....holds up great and it's waterproof
post #3 of 12 (permalink) Old 09-15-2008, 12:00 PM
i like it.... looks good chop007......cain't beat the price !!!.....gotta always be thinkin!!!!!!.........
KUDZOO is offline
post #4 of 12 (permalink) Old 09-15-2008, 12:27 PM
arjan's Avatar
i've been looking for a rad guard to my biggest issue with it what wil it do temperature wise wont it block air flow for cooling the engine have you noticed any difference other than that it looks much better than does shinny things going around
arjan is offline
post #5 of 12 (permalink) Old 09-15-2008, 12:53 PM
dallasdon's Avatar
Great job! You've saved us a lot of money and thank you.
'09 Versys -Green
TET'68 Survivor
dallasdon is offline
post #6 of 12 (permalink) Old 09-15-2008, 01:24 PM
Darth Lefty's Avatar
Velcro is good stuff. You can also consider 3M VHB tape for this sort of thing. Not as removable but holds stuff really well, way better than you expect. You can get it at Wal-Mart next to the other mounting tapes, it's the gray stuff with the red backing.
I'm calm like a bomb!
Darth Lefty is offline
post #7 of 12 (permalink) Old 09-15-2008, 01:37 PM
hellcatz's Avatar
Send a message via Yahoo to hellcatz
That is awesome! Great job!
Think this just became my mini-project for this weekend.
Ideas like this is why I love this site...
hellcatz is offline
post #8 of 12 (permalink) Old 09-15-2008, 01:49 PM Thread Starter
there's no negative airflow issues, it sits of the grill completely, adhears to the tanks, so it's about a quarter inch off the grill fins, if you look at the finished pics , i went a step further and punched a few round holes in the divided areas, just to prevent hotspots.....
post #9 of 12 (permalink) Old 01-20-2010, 04:40 AM
great job!
That is called American ingenuity... Why spend a fortune on every custom plastic part from china!
phdmam is offline
post #10 of 12 (permalink) Old 02-16-2010, 01:30 AM
Send a message via Skype™ to Tom327Cat
Thanks for the VHB tape tip! Used that and some rubber sheeting to make a el-cheapo fender extension.
Tom327Cat is offline
post #11 of 12 (permalink) Old 02-17-2010, 06:47 AM
That looks like a piece of ruber roof membane, is that what it is? I was thinking of using that but was concerned it would be to flexible. Looks like I have to hunt down some VHB tape.
Mike
WindWalker is offline
post #12 of 12 (permalink) Old 02-18-2010, 04:17 PM
It is just some 1/8" rubber sheeting that I had laying around the shop. If I remember correctly, it was being used to keep steel strapping off a transformer in shipment, so I am pretty sure it is just plain rubber.
Similar Threads
Radiator Grill Cover lost84001 Modifications - Performance - V-650 10 08-03-2010 07:48 AM
Radiator Guard dallasdon Modifications - Cosmetic - V-650 24 08-02-2010 08:39 PM
Versys Radiator papabear General Discussions - V-650 5 10-23-2008 04:38 PM
Radiator Fan Crapped out GregScuba General Discussions - V-650 1 10-17-2008 03:29 PM
radiator cover yoyo Modifications - Cosmetic - V-650 5 07-05-2008 05:47 PM
