Anyone have a cruise control or throttle clamp on their Versys? - Kawasaki Versys Forum
post #1 of 14 (permalink) Old 09-07-2008, 10:33 PM Thread Starter
Question Anyone have a cruise control or throttle clamp on their Versys?
I haven't looked around anywhere but I thought some of you may have one already and if you could tell me what you think is the best option I'd appreciate it.
stryker75 is offline
post #2 of 14 (permalink) Old 09-07-2008, 11:01 PM
DragonBreath's Avatar
I have the Vista Cruise lock and I'm very happy with it. Installation was pretty straightforward and it holds the throttle just like it should. Actually, I need to tighten mine up a bit, but other than that, it does a good job.
I used a Crampbuster for a good while, but I did not like the fact that it got in my way when I did not want to use it (like around town). I always meant to trim it down so it would ride beside my hand, but I never did.
BTW, there are a few different models of the Vista lock. I used the one that is for all bikes except Yamahas. It's a bit different from the true "universal" model that they make. I think the universal one is a bit more bulky if I recall.
Chris in Oneonta, NY
>>>> states on a bike <<<<
>>>> East Coast done <<<<
>>>>> Westward HO! <<<<<
DragonBreath is offline
post #3 of 14 (permalink) Old 09-07-2008, 11:30 PM
i run the universal vista cruise...it's a little bulky but i'm use to it know, happy so far
tsunamichop007 is offline
post #4 of 14 (permalink) Old 09-08-2008, 04:20 PM
Machog's Avatar
This is my set up, Vista cruise and throttle rocker. Took top bolt out of throttle housing, small hex spacer, new longer stainless bolt. It was the only neat way I could find to get it on there.
Machog
Machog is offline
post #5 of 14 (permalink) Old 09-10-2008, 10:53 AM
Lukejt's Avatar
I tried the cramp buster but I can't even get myself to ride with it for a couple minutes. I HATE how slippery it is. I squeeze the grip on the outside, and the CB is really slippery plastic. I think they should coat it with a rubbery skin to make it grip your glove better. I was being cheap when I ordered the CB.
Lukejt is offline
post #6 of 14 (permalink) Old 09-10-2008, 07:25 PM
I have the Vista- Cruise, and it works great!!! I put them on all of my bikes.
Todd
tapntx is offline
post #7 of 14 (permalink) Old 09-11-2008, 08:40 AM
I have the Throttlemeister, and it works just fine. Now if I could just figure out how to use it with hand guards . . . . - Hank.
hsfarber is offline
post #8 of 14 (permalink) Old 09-12-2008, 09:49 AM
Kaoko installed. Works great!
Bill
Versys
F650GSD
FLSTSCI
XR650L
Tri Scrambler
XR50
SRX600
Zuma 125
T100R
Aero 50
EZ90
PA50
States by MC
Bad-Tat is offline
post #9 of 14 (permalink) Old 09-13-2008, 05:18 PM
boogie's Avatar
I also have the Vista Cruise. Works as well as any throttle lock.
boogie is offline
post #10 of 14 (permalink) Old 09-13-2008, 07:48 PM
StonedGP's Avatar
I have the Kaoko, exactly what i was looking for.
http://www.kaokousa.com/
StonedGP is offline
post #11 of 14 (permalink) Old 12-15-2008, 12:47 PM
joshmedley's Avatar
will the kaoko or throttlemeister work with the barkbuster handguards? Machog which vista cruise do you have?
joshmedley is offline
post #12 of 14 (permalink) Old 12-15-2008, 05:31 PM
Machog's Avatar
jm, this is what I have, didn't get it from here, got it from my local dealer.
http://www.cajuncycleacc.com/item192.htm
Haven't checked, but assume Versys has the standard 1" bar diameter, I took it off my Valkyrie, KLR 650, it was fine on both of those.
Machog
Machog is offline
post #13 of 14 (permalink) Old 12-15-2008, 11:20 PM
Guest
I have the Vista Cruise. It works great, its inexpensive, and doesn't interfere with
the hand guards.
Mike
mweaver is offline
post #14 of 14 (permalink) Old 12-16-2008, 07:42 AM
The Gorilla's Avatar
Machog
Standard bar diameter's 7/8". For the big cruisers it's 1".
The Gorilla is offline
Similar Threads
AudioVox ccs-100 Cruise Control versys_guy Technical Discussion - V-650 69 06-24-2010 01:36 PM
Kaoko Throttle Control installed under Modifications - Cosmetic - V-650 5 05-28-2009 10:19 AM
cruise control installed crazydave58 Technical Discussion - V-650 33 01-15-2009 11:37 PM
Throttle locks AlexDz General Discussions - V-650 19 01-07-2009 02:23 PM
Cruise Control dallasdon Modifications - Cosmetic - V-650 11 10-22-2008 12:54 PM
