Centech AP-1 Power Panel - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 09-06-2008, 07:45 PM Thread Starter
Ocean's Avatar
I plan to add a few electrical items to my V but I don't want the rat's nest of fuse holders and wires cobbled around my battery. Yes, I could have gone to the autoparts start and got a wire loom for a couple of bucks. But, I wanted something better, durable and meant for the job. I bought a Centech AP-1 Power Panel and installed that today.
It's a nice looking module - about the size of a deck of cards or a pack of cigarettes. I also bought the relay with the kit so I could actuate the power panel with the ignition. It took a bit of time and effort to get it installed, now that it is - I found the effort worth it. I know have an effective point to add my electrical items. Now my GPS can run on bike power instead of battery power. I hated when I forgot to change the batteries before a trip. No worries about that now.
I used the tool kit bay to install the Power Panel. But, what to do with the tool kit? I found it fits just next door right where the U-Lock is supposed to go. No worries. Even if you don't plan on installing one of these things - but you want some extra space under the seat - now you know where to get that.
Attached are the photos of the job.
This first one shows all the components together. Nicely wrapped up and battened down.
This image is showing the wire I used for the relay's key wire. I wanted to use the headlight because it doesn't come on until the engine is running. That's the only time I need the power to my accessories. Only problem though is the headlight remains on after you shut the engine off. I'll have to remember to turn the ignition off as well. I took the blue-yellow headlight wire from the relay box's #2 plug. If you strip off the black electrical tape - it's easy enough to find.
What it looks like inside:
I bought my power panel from cyclegadgets.com
Ocean is offline
post #2 of 7 (permalink) Old 02-20-2010, 09:26 PM
MotoSig's Avatar
Did you use a fuse between the battery positive terminal and the AP-1? I have an AP-1 that I'm looking to install on my Versys and am wondering if putting a 30A fuse between the battery and AP-1 is necessary, especially since it has a 60A rating.
MotoSig is offline
post #3 of 7 (permalink) Old 02-21-2010, 07:10 AM
Austin city limits's Avatar
Centech is good,,, but,,, Fuzeblock is the BESTEST!!! Trust me,,, it does things the Centech can't do...
http://www.fuzeblocks.com/
Austin city limits is offline
post #4 of 7 (permalink) Old 02-21-2010, 10:27 AM
A2RON's Avatar
Yes, use an inline fuse between the battery + and the terminal block (CENTECH or FUZEBLOCK).
Here is a picture of my Fuzeblock installation with an in-line fuse holder between the battery and Fuzeblock 12V+ source input (blue oval). I use a 30A fuse-not shown in the photo.
I looked at the CENTECH and went with the FUZEBLOCK because of its integral relay and easy switched/un-switched individual circuit setup (move the circuit fuse position). Downside is if the integral relay goes...........
Here is my wiring job: http://www.kawasakiversys.com/forums...ead.php?t=5571
A2ron
Charleston, SC
A2RON is offline
post #5 of 7 (permalink) Old 02-21-2010, 09:55 PM
MotoSig's Avatar
That FZ-1 fuse block is pretty slick...too bad I already paid for the Centech. Oh well, I'll keep it in mind for my next bike someday!
MotoSig is offline
post #6 of 7 (permalink) Old 02-22-2010, 08:15 AM
cabrown's Avatar
I need to get one of these soon. Leaning heavily toward the FZ-1, but what's the general consensus on this one?
http://www.farkleshop.com/Products.html
Or this one?
http://www.easternbeaver.com/Main/Pr...8.html#pc8only
Sarcasm is a privilege.......not a right.
08 Versys....1st bike and love it!
cabrown is offline
post #7 of 7 (permalink) Old 07-29-2010, 07:27 PM
I like the fuse box made by eastern beaver, it has an external relay, so that you can replace it if necessary, no soldering required, just plug and play.
springroll2go is offline
Similar Threads
Do I need a Power Commander... JimmyC Modifications - Performance - V-650 17 07-25-2010 04:47 PM
Heres what i did for more power: myorangecamaro General Discussions - V-650 63 11-19-2008 01:00 AM
Power Commander bornrider Technical Discussion - V-650 4 09-07-2008 09:27 PM
Power Outlet dallasdon Modifications - Cosmetic - V-650 8 08-21-2008 05:31 PM
More Power! myorangecamaro General Discussions - V-650 0 05-03-2008 10:52 PM
