Installing LED License plate frame - Kawasaki Versys Forum
post #1 of 2 (permalink) Old 09-05-2008, 09:42 AM Thread Starter
I got a plate frame that has an aux brake light and turn signals that I'd like to install. Anyone done anything like this... Is it difficult? Anything I should look out for? Tips?
Anyone want to come over and help me, I'll buy the beer!
mrb42 is offline
post #2 of 2 (permalink) Old 09-05-2008, 11:02 AM
Guest
I did something similar and bought 2 GYB Versa (http://www.amazon.com/GYB-Products-P.../dp/B0013LDA8E) and placed one on the bottom side and one on the top side of the plate (it was cheaper than buying those ready made plate frames). I drilled a hole in the plastic right behind the plate and ran the wires through. I bought a bunch of Posi-Taps and tapped into the wires coming from the tail light and turn signals coming out from under the seat. The Posi-Tap made it very easy. For the break wire I ended tapping into the wrong wire (the tail) but swapping them was a piec of cake with the Posi-Tap. Note that I have no affiliation with any the brands mentionned above, but it ended up being an easy job. You can see (not very clearly though) the finnished job in my gallery.
Good luck.
FouDuFafa is offline
Similar Threads
New skid plate ! ! ! andyversys General Discussions - V-650 47 02-25-2009 05:44 PM
Plate Light Bicyclebob Modifications - Cosmetic - V-650 3 10-07-2008 08:50 PM
License Plate Bracket W/Light tweak General Discussions - V-650 2 08-25-2008 09:57 PM
Problems installing Kawasaki windscreen? luckydog Modifications - Cosmetic - V-650 14 08-23-2008 09:40 PM
Installing Givi side cases actar911 Modifications - Cosmetic - V-650 10 04-27-2008 07:56 AM
