Givi Case Stoplight Wiring - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 09-04-2008, 09:22 AM Thread Starter
Can anyone tell me which two of the brake light wires to hook the case stoplight up to ? I see three wires, one red, one brown, and one with a white stripe. I already tried to botch this install once - hogged out too much plastic on the rack mount - and don't want to mess anything else up.
renman is offline
post #2 of 6 (permalink) Old 09-04-2008, 09:31 AM
Shane99's Avatar
I will be installing mine this weekend if you can wait till then I can post pics and info for you.
Shane99 is offline
post #3 of 6 (permalink) Old 09-04-2008, 09:46 AM Thread Starter
I'm in no hurry at all. Thanks !
renman is offline
post #4 of 6 (permalink) Old 09-13-2008, 09:34 PM
Shane99's Avatar
The wiring was simple it took me about 20 minutes from start to finish. At the brake light use the blue wire to blue on the givi wire and the blacck wire at the brake light to black on givi wire everything else is pretty much laid out for yah. Let me know if pictures would help you more.
Shane99 is offline
post #5 of 6 (permalink) Old 09-14-2008, 11:02 AM Thread Starter
OK I have a blue stripe and a white stripe wire. i'll try that
renman is offline
post #6 of 6 (permalink) Old 09-14-2008, 12:12 PM Thread Starter
Duh...blue stripe and black wire,whatever. Once I aligned the connector between the case and rack correctly worked fine. Thanks !
renman is offline
Similar Threads
Givi Top case james williams Modifications - Cosmetic - V-650 50 05-02-2011 10:40 PM
Driving Lights - Installation and Wiring Tips 08 Versys Modifications - Cosmetic - V-650 46 12-15-2009 08:37 PM
GIVI Top Case Rack Mount Boltos General Discussions - V-650 10 07-17-2008 06:27 PM
Stock side-cases: What top-case to use? dhesselink Modifications - Cosmetic - V-650 6 06-24-2008 03:59 AM
Question about Kawi top case Briar Rabbit Modifications - Cosmetic - V-650 2 06-17-2008 08:28 PM
