Gen 3 V-Stream shield; knobs don't stay tight - Kawasaki Versys Forum
Like Tree5Likes
  • 2 Post By onewizard
  • 1 Post By weljo2001
  • 1 Post By motorboy
  • 1 Post By onewizard
post #1 of 14 (permalink) Old 01-25-2017, 06:32 AM Thread Starter
Text / Message/Mistaken for a Young Buck
Originally Posted by leeinmemphis View Post
Thanks for the info OneWizard. I've been riding bikes for almost 30 years so I have a pretty good hand on setting the bike up. I have a set of heat demon grips here just waiting to be put on that I have left over from another project before. I already have peg lowering brackets, fuzeblock, gps mount, thermobob, givi side cases on order. Only problem is going to be finding time to tear it apart when I won't be wanting to ride it.
Me over 40 years of riding, just thought it appropriate to post this, funny thing is I missed something real important, that 2015 owners have come across. The Adjustable wind screen is to have a concave washer on each adjustment knob, plus 1 large flat washer, many of us have found 2 large flat washers, end result is knob vibrates loose and in one case the knob went missing on a ride. I am sure Eddie can fill you in on this.
post #2 of 14 (permalink) Old 06-22-2017, 12:19 PM
I've gone back-and-forth between the OEM windshield and my PUIG 5999 several times, and it's ALWAYS been a PITA! You end up needing another pair of hands (w/ REALLY long fingers!) to hold all the little bits that try to fall out once you've removed the four bolts, and two 'adjuster' knobs.
As I was doing it again yesterday, I decided to look into my SERVICE MANUAL (for a change......) to see what Kawi says to do. SAME thing I've been doing, so I started in on the job. Removed BOTH 'adjuster' knobs, started on the bolts, then a thought 'hit' me - what if I put a nut onto the bolts that the 'adjuster' knobs screw onto...?
I finger-tightened two, removed the four screws and VOILA! - NOTHING fell onto the floor! Changing windscreens went from a chore, to a FIVE minute pleasure. Here's a pic of the windscreen-mounts w/ the two nuts replacing the 'adjuster' knobs.
BTW - look CLOSELY at the washer in the first pic. It's SUPPOSED to be a "spring" washer OEM, but mine came w/ just a flat-washer, so I went to a bolt supply and got a proper "spring" washer, and installed it.
NOW I'm NOT looking all over my shop floor for pieces like that when they fell down removing my screens "by the book"!
ID:	165919   Click image for larger version
post #3 of 14 (permalink) Old 08-30-2017, 10:12 AM
Doug Just Doug's Avatar
Lovin' my Nat'l Cycle V-Stream shield, but minor annoyance: the knobs loosen up quite often. That didn't happen with the OEM or the Puig shields I used previously. I imagine lock washers are the solution (or eat more Wheaties), but I was just wondering if anyone else is experiencing this?
2015 Versys 650 ABS
AMA, Retreads Int'l.
Doug Just Doug is offline
post #4 of 14 (permalink) Old 08-30-2017, 10:21 AM Thread Starter
Installation Error
Yes, many of us 2015 owners, I will try and find the Post, FastEddie posted.The concave washer is missing on many, including my 2015, I purchased some from a place called Spae Naur. After installing, and 14,000 KM later, no problems.
Here is one of his posts, he describes as a spring washer that was missing, same for me.
http://www.kawasakiversys.com/forums...ghlight=washer
quexpress and Doug Just Doug like this.
post #5 of 14 (permalink) Old 08-30-2017, 12:58 PM
No issues with mine on my V-1000
Doug Just Doug likes this.
The difference between genius and stupidity is that genius has its limits. Albert Einstein
post #6 of 14 (permalink) Old 08-30-2017, 10:47 PM
motorboy's Avatar
And I thought I was the only one-and yes only with the National Cycle sport Tour shield no other windshields- including the National Cycle shorter Sport shield-so I put it where I wanted it and a drop of blue lock tight on each side-so far so good--oh I put a small drop of white paint on the adjuster knobs so I could tell if it moved..
Deep in Cajun Country
motorboy is offline
post #7 of 14 (permalink) Old 08-31-2017, 01:20 PM
Weird, right? I like the threadlocker idea; might do that or add a lock washer. Thanks.
2015 Versys 650 ABS
post #8 of 14 (permalink) Old 09-07-2017, 04:37 PM Thread Starter
OEM Two Height Adjustments Available
Thought I would re-post this.Several have commented about the extra height of the OEM shield, very easy to do, while your at it , make sure you have a concave/ spring washer under each knob, my bike and many others didn't have it, FastEddie alerted me about this, some have had the knob vibrate off the bike, no BS here, I don't think you would be impressed having your shield come at you
A photo of the height I use, as I don't like looking through the shield, especially with bug splatter
The raised , extra height available, giving about 1.5 inches above the slot opening
post #9 of 14 (permalink) Old 11-07-2017, 02:23 PM
Following-up, I installed some lock washers and the knobs haven't loosened a bit since.
2015 Versys 650 ABS
post #10 of 14 (permalink) Old 10-04-2019, 10:19 AM
I noticed this too! Thought I was going crazy!!! Threadlocker seems like my answer....seeing as I already have some
dkurant is offline
post #11 of 14 (permalink) Old 10-04-2019, 03:29 PM Thread Starter
really bad idea. The proper thing is a concave washer that seems to be missed by whoever is building these. I copied several posts, 1 was in the link above,I say using loctite / thread locker is a bad idea, because have a close look at that nut, it wouldn't take much to destroy it or damaged the track it is mounted in, just 2 extra threads of using 242 blue loctite you may never get it loose and may destroy the knob. A star lock washer is also a poor substitute, the concave washer allows for ambient temperature change and vibration.
DinkinFlicka likes this.
post #12 of 14 (permalink) Old 10-04-2019, 04:26 PM
...the concave washer allows for ambient temperature change and vibration....
Also sometimes called a "spring", or "cup" washer.
post #13 of 14 (permalink) Old 10-04-2019, 04:34 PM
In the three years (15000 miles) that I had the 15' Versys I never had the knobs come loose. With the OEM shield or the GIVI.
Duffy is offline
post #14 of 14 (permalink) Old 10-05-2019, 12:31 PM Thread Starter
You must be one of the lucky ones, here in Canada it is common to be missing that washer, my 2015 was missing it and I almost lost one knob, my contacting FastEddie enlightened me. I went to a specialty fastener place here and bought two sizes, SpaeNaur also referred to as Ed said disc spring or Belleville washer , get stainless steel https://spaenaur.com/wp-content/uplo...rs-D39-D64.pdf
