Replacement rider pegs - Page 2 - Kawasaki Versys Forum
Like Tree12Likes
post #21 of 28 (permalink) Old 12-01-2019, 02:54 PM
kardan's Avatar
Hola, I am looking for wide footpegs.
I found this on aliexpress. Somebody have that type of pegs?
Is that OK, how durable are they, is that even safe for usage?
I have large foot ( size 14 US ), so I wish larger( wider ) footpegs
https://www.aliexpress.com/item/3298...chweb201603_53
Gas for heating, diesel for plowing, electricity for cooking, petrol for driving
kardan is offline
post #22 of 28 (permalink) Old 12-06-2019, 11:00 AM
Lours_Polaire's Avatar
Looks like aluminium ... Would not stand on a thin aluminium plate like that ...
My 2 cents
LOP
kardan likes this.
Lours_Polaire is offline
post #23 of 28 (permalink) Old 12-06-2019, 12:47 PM Thread Starter
I had something similar that I got off eBay........they worked well but those look a bit "lighter". Check out post #13......that's what I used.
kardan likes this.
Duffy is offline
post #24 of 28 (permalink) Old 12-06-2019, 02:56 PM
I just added some better pics to "Post #18".
kardan likes this.
post #25 of 28 (permalink) Old 12-06-2019, 05:09 PM
kardan's Avatar
My 2 cents
LOP
Yes it is aluminum, but that parts is connected on OEM footpeg, you remove OEM rubber on footpeg and add this "footpeg" instead of rubber.
I think it will holdwery well, if this thin part break I still stand on OEM he need to hold my weight.
From pictures I think that foopeg are little less than 10mm thick.
Well it is not expensive I can buy them and test them with 100+ kg of cement, with hammer also, to see will that plate bend, break so I can see is it safe.
Lours_Polaire likes this.
kardan is offline
post #26 of 28 (permalink) Old 12-06-2019, 05:30 PM
kardan's Avatar
I was also looking something like that.
How much vibration do you have on that?
kardan is offline
post #27 of 28 (permalink) Old 12-06-2019, 07:57 PM Thread Starter
Very little vibration.....and very good "grip" on the bottom of your boots.
kardan likes this.
Duffy is offline
post #28 of 28 (permalink) Old 12-07-2019, 02:43 PM
As Duffy said: NOT much!
