GPS mount - Kawasaki Versys Forum
Like Tree5Likes
  • 4 Post By Lampie
  • 1 Post By zirconx
post #1 of 12 (permalink) Old 07-24-2017, 12:57 PM Thread Starter
Lampie's Avatar
GPS mount
I bought a GPS mount from SW Motech.
Now it's located just in front of you, you don't have to look down anymore.
Also no more issues with the tank-bag hitting your GPS
Mounted heated grips, also the original handguards
Kawasaki and Anita = Kawanita
Lampie is offline
post #2 of 12 (permalink) Old 07-25-2017, 09:30 AM
Doug Just Doug's Avatar
Liking my SW-M GPS mount, too -- very sturdy piece. I have a RAM X-Grip mounted to it, which holds a large waterproof/vibration proof cell phone that I'm using solely in GPS mode.
2015 Versys 650 ABS
AMA, Retreads Int'l.
Doug Just Doug is offline
post #3 of 12 (permalink) Old 07-25-2017, 10:48 PM
Very nice mounting solution. And I like the brick work in your courtyard too.
post #4 of 12 (permalink) Old 07-25-2017, 11:02 PM
Thanks for sharing.
Fastoman is online now
post #5 of 12 (permalink) Old 07-26-2017, 07:31 AM
Has anyone figured out what the unused threaded holes on the triangular mount brackets (visible in the 2nd photo above) are for? Maybe I missed it in the instructions.
2015 Versys 650 ABS
post #6 of 12 (permalink) Old 07-26-2017, 09:18 AM
RAM balls.
Doug Just Doug likes this.
zirconx is offline
post #7 of 12 (permalink) Old 07-27-2017, 01:06 AM
That looks like a great mount, as you say right in front of you.
I would like to hardwire mine in.
What wires would you use to do this?
I know there is wiring there for accessories.
Which ones do you think I should use for the GPS?
tonyw is offline
post #8 of 12 (permalink) Old 07-27-2017, 08:39 AM
Originally Posted by zirconx View Post
RAM balls.
Nice.
2015 Versys 650 ABS
post #9 of 12 (permalink) Old 07-27-2017, 11:22 AM
BKP
BKP's Avatar
I have the same SW Motech mount for about a year now, with no issues. Originally, I was going to hardwire it in, as well. However, I've installed the relay / gear indicator / power socket combination, and just keep it plugged into the socket, on the left side. Works fine, and it's all easily removable if I upgrade the GPS.
SW Motech
Ride safe...
Barry
2015 Versys 650 Pearl White
[space holder for farkles...]
BKP is offline
post #10 of 12 (permalink) Old 07-28-2017, 12:52 AM
jpd
I make my own hard wire adapter from a spare lighter adapter. Take apart the power plug and remove the circuit board. Unsolder the connections and solder on wires with connectors for your acc.conection. After I test fit it I also shorten the power lead to the gps and resolder them to the board. Reinstall it in the plastic plug and tape it up. I get a much more reliable power connection to the gps. I took a bike to the Outer Bankes with a new power plug and it was corroded on the inside by the end of the weekend.
Jeff
jpd is offline
post #11 of 12 (permalink) Old 07-28-2017, 04:54 PM
From what I understand there is wires already available that can be used for accessories.
tonyw is offline
post #12 of 12 (permalink) Old 07-29-2017, 10:27 AM
jpd
There are connections under the left side fairing. I plug my rocker switch into them and then connect my modified power supply into the switch. I have had problems with cigar lighter plugs due to vibration or corrosion in the plug giving me "power disconnected" messages on the gps. Even an all weather plug will still corrode after time. It usually goes bad just when you need it the most. You could do the same with a auto power supply for a cell phone usb or firewire. You can hide the power supply down under the fairings and only have the power lead run to the location you need it.
Jeff
jpd is offline
