Riser Block for Front Seat Lift Mod - Page 5 - Kawasaki Versys Forum
Like Tree11Likes
post #81 of 88 (permalink) Old 08-20-2018, 08:19 AM
Doug Just Doug's Avatar
I had the riser 3D printed a while ago but finally got around to installing it yesterday. I wasn't having a big problem with the tilt of the seat, but figured I'd try it anyway. On a 45 minute commute to work this morning I could definitely tell the difference -- guess I had been pushing myself back in the seat more often than I knew. I'm sure this will make a bigger difference on longer rides. I'll likely get an aftermarket seat at some point, but in the meantime this is a great low-cost mod. AT 5'9" I can still (barely) flat-foot the bike with the seat riser in place and a thick sheepskin seat pad. BTW, you'll need two M6 x 40mm hex-head bolts, and two M6 flat washers unless you're using flange-head bolts. I think 40mm is minimum bolt length; others have used 45mm or 50mm. I went with stainless bolts and washers.
pdx_greg likes this.
2015 Versys 650 ABS
AMA, Retreads Int'l.
Doug Just Doug is offline
post #82 of 88 (permalink) Old 12-13-2018, 11:12 AM
Rawkstar320's Avatar
Hey everyone, I am still alive!
A few things, first thing is since I never set up my PM to email me notifications, I got busy with life and forgot to check my PM box for a while. o_0
But more importantly, I definitely cannot make the risers for people anymore. It is simply too much work managing everything, however, the files are out there on Thingiverse ( https://www.thingiverse.com/thing:1775953 ) and there are TONS of 3D printing services that can manufacture the parts for around $10-$15 per part --- which is WAY cheaper than it costs for me to build it.
Good luck all, and ride safe!
Check out my
Rawkstar320 is offline
post #83 of 88 (permalink) Old 12-13-2018, 11:30 AM
Receive Email Notification on PM sent
Receive Email Notification on PM sent , set correctly.
onewizard is online now
post #84 of 88 (permalink) Old 12-14-2018, 09:39 AM
thanks for making the ones you did. I am still using mine and it will go with the bike when it is sold or traded in. Take care, and glad to see your name. I also go for weeks without checking in.
rayj
2009 Versys (Mine's Green)
rayj is offline
post #85 of 88 (permalink) Old 09-25-2019, 07:16 AM
REDHORSECA's Avatar
Red face
Just letting Rawkstar320 know his 3D seat block is still going strong.
I downloaded your STL file and printed a set. Saves me from having to take a bunch of measurements to draw one up in 3D.
I printed a couple for my Versys bikes.
I have it installed and immediately felt a comfort difference for the better.
REDHORSECA is offline
post #86 of 88 (permalink) Old 01-08-2020, 03:01 AM
alpy's Avatar
Hi,
If there is still an interest in 3D printed riser blocks, I made my own which provides the support at original locations of the seat, but adding 12mm height.
https://www.thingiverse.com/thing:4089614
Cheers,
Alpy
V650/2015
alpy is offline
post #87 of 88 (permalink) Old 01-08-2020, 03:43 PM
Try this link to make your own for about $2....
https://www.kawasakiversys.com/forum...riser-mod.html
post #88 of 88 (permalink) Old 01-08-2020, 03:45 PM
Or make your own from metal for about $2....
dadsafrantic likes this.
