Mounting Kawasaki top case - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By whiting57
post #1 of 13 (permalink) Old 06-13-2017, 01:15 PM Thread Starter
Indelibility's Avatar
The rack the the top case and mount attach to (on the grab rails) has been on backorder for weeks. Is there another option I can use to mount the OEM top case and base plate? Does one fro Givi work?
Indelibility is offline
post #2 of 13 (permalink) Old 06-13-2017, 01:58 PM
I used the Givi Rack on my Versys 1000
Givi Rack by weljo2001, on Flickr
Givi E-55 Topcase by weljo2001, on Flickr
The difference between genius and stupidity is that genius has its limits. Albert Einstein
post #3 of 13 (permalink) Old 06-13-2017, 02:20 PM Thread Starter
I need this whole section since the 650 doesn't come with the rear rack from the factory.
post #4 of 13 (permalink) Old 06-13-2017, 02:35 PM
Your pic looks like what Joe has on his 1000.
post #5 of 13 (permalink) Old 06-13-2017, 03:01 PM
I used the rack from Givi on my 650LT, it was around $35 I think. Works great. Here's my post about it: http://www.kawasakiversys.com/forums...rks-great.html
Here's the rack on RevZilla: https://www.revzilla.com/motorcycle/...-650-2015-2017
You'll need a Givi plate to go on the rack also. If you already have the Kawasaki plate - I think that's just a Givi plate and will fit onto the SR4114 rack.
zirconx is offline
post #6 of 13 (permalink) Old 06-13-2017, 04:22 PM Thread Starter
Yep, I see the Givi SR4114 Top Case Rack on Revzilla, and I have the Kawasaki mount. I'm just trying to find that plate tar hours between the two rack mounts and the top case mount.
This piece in red:
Is this all I need?
post #7 of 13 (permalink) Old 06-13-2017, 07:35 PM
You do need a plate. I used a Givi M7 with my SR4114 rack. I think the M7 looks better than the Kawasaki branded Givi plate. I think the Kawasaki branded Givi plate is a Givi E251. I am not sure if that plate will fit on the SR4114 rack. I'm guessing not.
https://www.revzilla.com/motorcycle/...op-case-plates
zirconx is offline
post #8 of 13 (permalink) Old 06-13-2017, 09:01 PM Thread Starter
I was looking at those. Luckily the Kawasaki plate is flat with any abundance of mounting holes.
I'll report back later to see if the two are compatible, thanks for the assistance!
post #9 of 13 (permalink) Old 06-13-2017, 09:34 PM
whiting57's Avatar
you could try twistedthrottle.com ..... sw motech carries alternatives for the givi OEM and Kawasaki top case brackets
aboyandhisversys likes this.
And as I flipped into 6th, I could not remember a damn thing she said ....
whiting57 is offline
post #10 of 13 (permalink) Old 06-14-2017, 09:03 AM
Doug Just Doug's Avatar
I had the Givi SR4114/M7 combo on my 2015 so that works for sure. The SR4114 wouldn't work with the SW-Motech side racks I wanted to install, so I switched the top case set-up to the SW-Motech mounts and steel luggage rack (with Givi Monokey adapter kit so I could use my V-47 case). That's two combos that can work for you. Below is the SW-M set-up, minus the Givi adapter kit, which I hadn't yet installed when the pic was taken.
2015 Versys 650 ABS
AMA, Retreads Int'l.
Doug Just Doug is offline
post #11 of 13 (permalink) Old 06-14-2017, 11:03 AM
This piece in red:
Is this all I need?
You ALSO need the two pieces alongside your 'red' outline. They attach to the handguards, then the others attach to them. That is what I did, BUT I would have done the other had I had the opportunity. Here's pics of mine (and the aluminum piece I made to attach my tent, etc). I also disabled the "sliding" function of the rack.
As you can see, I also added additional brake lights as the rack can obscure the OEM lights from certain angles.
post #12 of 13 (permalink) Old 06-14-2017, 01:16 PM
The Givi SR4114 is that part (it stands in for that part) outside the red area.
zirconx is offline
post #13 of 13 (permalink) Old 06-16-2017, 11:22 AM Thread Starter
The Givi rack is now confirmed to work with the Kawasaki base plate. I had to drill two new holes in the plate but for $35 I can't complain.
ID:	123202   Click image for larger version
