Fenda Extenda - Kawasaki Versys Forum
Like Tree4Likes
  • 1 Post By kballowe
  • 1 Post By weljo2001
  • 1 Post By Wolfcamp
  • 1 Post By trialsguy
post #1 of 8 (permalink) Old 02-26-2017, 08:31 AM Thread Starter
kballowe's Avatar
Fenda Extenda
Just installed the Puig Front Fender Extender for the Kawasaki Versys 650 / 1000.
Not much for instructions - but it appeared to go together quite well. I added a bead of blue RTV silicon all the way around the edge because (in my mind) it would help to keep all the road crap from getting between the two parts - and might actually help to better hold the assembly together.
It makes one a bit nervous, drilling four holes into a perfectly brand new motorcycle fender...... and smashing those little plastic push-pins into place......
quexpress likes this.
kballowe is offline
post #2 of 8 (permalink) Old 02-26-2017, 09:53 AM
looks good do you have a link to were you got it?
post #3 of 8 (permalink) Old 02-26-2017, 02:34 PM
I used Gorilla Glue Epoxy when i put one on my 650 didn't drill any holes and never had an issue.
post #4 of 8 (permalink) Old 02-27-2017, 12:18 PM
Wolfcamp's Avatar
Originally Posted by kballowe View Post
Just installed the Puig Front Fender Extender for the Kawasaki Versys 650 / 1000.]
I've done this on a couple of bikes I've owned. I did not want to drill holes so what I did was use JB Weld. I roughed up the matching surfaces, applied the stuff, let it dry and that was it. It was probably on there more firmly than with screws.
2016 Versys 650 LT, Orange
Wolfcamp is offline
post #5 of 8 (permalink) Old 02-27-2017, 02:33 PM
Doug Just Doug's Avatar
Thanks for the posts; I've got one waiting to be installed the first time I have to pull the front wheel off for any reason. I've put them on prior bikes, always using the supplied screws -- I see they now use the plastic rivets. Funny how nobody feels safe relying solely on the supplied adhesive strips, I know I never have. :^)
Doug Just Doug is offline
post #6 of 8 (permalink) Old 02-27-2017, 02:48 PM
Almost 9 years ago, I installed my Fenda Extenda using only Shoe Goo. It's still holding fine.
I could not bring myself to drill any holes in my front fender.
trialsguy is offline
post #7 of 8 (permalink) Old 02-28-2017, 09:42 AM Thread Starter
kballowe's Avatar
In the instructions, it says that the adhesive strips are only to hold the fender extender in place in order to drill the holes.
Ya could add some more strips, let it sit a couple of days - and then it would probably work just fine
kballowe is offline
post #8 of 8 (permalink) Old 03-01-2017, 12:48 AM
I removed the crap doublesided tape from my Pyramid fender extender replacing it with 3M acrylic doublesided automotive grey mount tape. I lined the outside profile of the fender extender and then laid some strips across.
Been over three years now and have even run over kangaroo road kill and its still on.
No holes required.
BTW. the top rivet looks like it is off center.... measure 3 times cut once.
Gigitt is offline
