Stereo install help for dummies please? - Kawasaki Versys Forum
Like Tree10Likes
post #1 of 27 (permalink) Old 02-03-2017, 07:25 PM Thread Starter
Joey Rocket Films's Avatar
Problem resolved 2011 Versys 650
I bought a pyle 300 watt system and I pretty much have placement all set for the speaker and amp but I'm not sure where to connect the power and negative wires. I don't want it draining my battery of course so I'd like to splice into something that only has power once the engine in running. Does anyone have a recommendation or link to an install thread? I'm not great with wiring and I know a few basics but I'm also not afraid to learn and apply. Pics would be extremely helpful if possible.
Because I want to
Ride it like you stole it but also like you wanna be able to ride it to work the next day
My V - Z.A.B. 2.0
Joey Rocket Films is offline
post #2 of 27 (permalink) Old 02-04-2017, 10:14 AM
find a switched power source (power that turns on and off with the key {i like using the parking lights or taillight}) and use it to trigger a relay and run the main power for the radio (or anything else you plan to power switched) thru that relay (with a fuse inline)
Joey Rocket Films likes this.
post #3 of 27 (permalink) Old 02-04-2017, 10:39 AM Thread Starter
Thanks so much for taking the time to reply! I agree about the switched power source. Here's where my lack of knowledge comes in. What does trigger a relay mean? I know what relay look like but I don't know the rest. Am I supposed to splice into a wire that runs to a switched relay? Any chance you have a pic to show please?
As far as "with a fuse inline" goes, are you referring to the fuse block that I have in the picture? Thanks!
My V - Z.A.B. 2.0
post #4 of 27 (permalink) Old 02-04-2017, 11:05 AM
no problem,
a relay is nothing but a switch, it turns things on and off.. heres a pic on how to wire one..Wiring Diagram 4 Pin Relay | Zen Diagram
so you will want a line going from your battery positive terminal to #30/51 (some say 30 some say 51)
then a wire from pin #85 to a good ground (or the negative terminal of the battery)
then pin #87 will be the one you want to hook the positive power wire of your radio into
then pin #86 will be your "trigger wire" and needs to be a "switched" power supply (i recommend splicing into the parking lights like ive done here (only needs to be the positive wire)
and yes the fuse in the photo is perfect
post #5 of 27 (permalink) Old 02-04-2017, 11:18 AM Thread Starter
no problem,
Very much appreciated! Great explanation. Hopefully I'll be able to make sense of those diagrams. Will I need to solder?
My V - Z.A.B. 2.0
post #6 of 27 (permalink) Old 02-04-2017, 11:41 AM
need..... well is truly a matter of opinion... you can solder and crimp and seal your connections but personally i just crimp and heat shrink and have never had a problem. some people ive worked with say you have to solder and seal every connection ever or you will burst into flames and die
post #7 of 27 (permalink) Old 02-04-2017, 01:23 PM
[QUOTE=silviefox;1326697...or you will burst into flames and die[/QUOTE]
silviefox - I think you will PROBABLY scare poor Joey....
You MIGHT "...burst into flames and SLOWLY MELT" is LESS frightening....
post #8 of 27 (permalink) Old 02-04-2017, 01:29 PM Thread Starter
Hahaha I catch your drift well. I won't be soldering...
My V - Z.A.B. 2.0
post #9 of 27 (permalink) Old 02-04-2017, 01:36 PM Thread Starter
Lol oh no, I don't scare easily he couldn't have said it better!
My V - Z.A.B. 2.0
post #10 of 27 (permalink) Old 02-05-2017, 11:28 AM Thread Starter
Holy crap I actually did it. Took it out last night and it sounds great. Luckily I only planned to use one of my speakers because I blew one of them somehow during the installation so it sucks I have no back up speaker if the main blows but oh well.
Funny this was I did end up having to do some soldering because I didn't have great quality connector so I soldered to make sure they would bond good enough.
Thanks so much for the help. My last question (maybe) is what to do with the exposed relay? Wrap it up in electrical tape or leave it be?
My V - Z.A.B. 2.0
post #11 of 27 (permalink) Old 02-05-2017, 12:55 PM
just mount it somewhere out of the way (i ziptie mine with a peace of double stick foam between it and whatever i mount it to)
and speakers are cheap and easy to come by and hook up , also see if the person you got them from will replace it under warranty
post #12 of 27 (permalink) Old 02-05-2017, 01:07 PM Thread Starter
Thanks. I'm all set as far as location goes but should I tape it up or leave it exposed the way it is?
That's a good point about the Warrenty. Thanks. I bought them new
My V - Z.A.B. 2.0
post #13 of 27 (permalink) Old 02-05-2017, 01:11 PM
as long as it isnt wire side up and and somewhere water will be dumping down on it all the time it should be just fine not coated in tape (if you wanna seal it to be over safe just use some liquid tape or hot glue, wrapping in tape isnt weather tight and will hold moisture in
post #14 of 27 (permalink) Old 02-05-2017, 01:21 PM Thread Starter
Here's the set up. Thought? Seat fits over everything fine
My V - Z.A.B. 2.0
post #15 of 27 (permalink) Old 02-05-2017, 03:47 PM
Joey - IF it was ME - I would use some 'shrink-wrap' on those exposed bits of the wires going to your relay, just in case....
quexpress likes this.
post #16 of 27 (permalink) Old 02-05-2017, 04:31 PM Thread Starter
I thought of that and grabbed some incase so I may use it. Thanks for the suggestion Ed.
My V - Z.A.B. 2.0
post #17 of 27 (permalink) Old 02-05-2017, 04:50 PM
post #18 of 27 (permalink) Old 02-07-2017, 07:50 AM
andyversystheworld's Avatar
Why is the wire wrapped around the terminal? Why not cut to fit?
BEST,
ANDY
Visit me at andyversystheworld on Facebook for Pictures and Updates.
andyversystheworld is offline
post #19 of 27 (permalink) Old 02-07-2017, 08:31 AM
ItsForrest's Avatar
That caught my eye also. Coiling wires is never a good way to deal with extra lengths, especially coiled around other wires. Keep in mind that coils are what are used to make electromagnets, transformers, etc. Coiling wires can have negative effects from creating interference in radios to causing voltage issues and other unwanted electrical behaviors.
The urge to buy terrorizes
ItsForrest is offline
post #20 of 27 (permalink) Old 02-07-2017, 08:35 AM Thread Starter
Because I have no idea what I'm doing!
PHX_Joe likes this.
My V - Z.A.B. 2.0
Tags
speakers, stereo, stereo install
