Shortening front blinker stalks - Kawasaki Versys Forum
 1Likes
  • 1 Post By dddd
post #1 of 19 (permalink) Old 12-31-2016, 09:04 PM Thread Starter
mully123's Avatar
I had shortened the rear blinker stalks on my c10 concours and thought I'd give it a try on my Versys stock front blinker stalks. In the pictures I only had the left one done 11/16 inch, hoping to lessening damage if and when I tip over. What do you think?
mully123 is offline
post #2 of 19 (permalink) Old 01-01-2017, 06:32 AM
Very much interested in your process. You need to show how you did it, otherwise you are just showing off! :-)
For the mater of protecting it, I removed the pair of clamping plates. The rubber boot is strong enough to hold the stalk, but will pop out if bent in a crash. Tested (unfortunately). It may still crack the lense, but you could definitely save a fairing from cracking.
dddd is offline
post #3 of 19 (permalink) Old 01-01-2017, 08:25 AM
How visible are the turn signals with the headlight on from 100 yards away?
Might want to add some SkeneDesign P3 turn signals to compensate.
post #4 of 19 (permalink) Old 01-01-2017, 10:19 AM Thread Starter
mully123's Avatar
I like your ideal of removing the clamps so it just pops out in case of a fall. When I do the right blinker I'll try to take some pictures, It's not hard to do but the cuts have to be precise or it could get expensive buying a new blinker.
mully123 is offline
post #5 of 19 (permalink) Old 01-01-2017, 10:26 AM Thread Starter
mully123's Avatar
Not a bad ideal, I have seen a lot of cars that you can't see their blinker because it's washed out buy the headlight.
mully123 is offline
post #6 of 19 (permalink) Old 01-01-2017, 03:27 PM Thread Starter
mully123's Avatar
I took some pictures while shortening the right blinker. You make three cuts, all of equal length (I did 11/16") One cut on blinker housing, one on the rubber boot and one on the post where the screw goes in to hold the assembly together. Then drill the hole in the post all the way threw and use a shorter screw(I used a #8x1/2" sheet metal) to reassemble. Used a hacksaw for the cuts and a file to level and clean up cuts.
mully123 is offline
post #7 of 19 (permalink) Old 01-01-2017, 04:06 PM
Thanks!
But tool-wise, I'm 1 cat short (or perhaps it's just the foreman inspecting?)
dddd is offline
post #8 of 19 (permalink) Old 01-04-2017, 07:00 AM Thread Starter
mully123's Avatar
Thanks!
You are welcome, and yes that is one snoopy cat, lol.
mully123 is offline
post #9 of 19 (permalink) Old 09-11-2017, 08:26 AM
Bale2011's Avatar
Can you show how you did this? Sounds like a great idea.
Edit: Disregard. I read your post again and I see you're just leaving out the plate and not modifying anything. That's a brilliant idea.
Bale2011 is offline
post #10 of 19 (permalink) Old 09-11-2017, 09:24 PM
Thanks. I would have kept that but in the end, with so much winter time to kill, I went for led blinkers (2" long) decently bright (https://www.admsport.com/en/clignota...rsel-del-arrow) with DIY adapter plates from thick garbage bin plastic and a led flasher relay. They barely exceed my crashbars width and they flex, so good chances of not breaking.
dddd is offline
post #11 of 19 (permalink) Old 09-13-2017, 11:03 AM
New Plastic Required
Joined the ranks of , yes new plastic needed , doing a tight left turn at 2KM/Hr , in second gear , GPS moment, yup, just a spit second and stalled my clutch hand went forward, just like hard braking, and Over we go, pushed the signal straight through the plastic , so much for the rubber mount. Waiting for my highway peg mounts to arrive to mount on my Sw Motech crash bars sitting on the garage floor. Yes the bars are unscathed as they are in the bubble wrap
post #12 of 19 (permalink) Old 09-13-2017, 11:32 AM
Bale2011's Avatar
How bad did your cowling crack when the signal pushed through it?
I'm kind of disappointed that Kawi won't design a break-away type signal mount, or at least relocate them (or point them forward) to where they don't protrude beyond a typical crash bar setup. I've checked around and it seems to be anywhere from $100 to $200 to replace a cracked cowling.
Bale2011 is offline
post #13 of 19 (permalink) Old 09-13-2017, 11:57 AM
No crack, a clean punch through, hole is now size of signal, not repairable, a back order item, go figure . $160 Canadian
post #14 of 19 (permalink) Old 09-13-2017, 01:26 PM
Bale2011's Avatar
I might just find a way to flush mount these so they sit within the crash bar protective range. Winter project.
https://www.revzilla.com/motorcycle/...ed-turn-signal
Edited to add: I've found this relay replacement to go along with the LED lights.
https://www.customled.com/products/e...-flasher-relay
Bale2011 is offline
post #15 of 19 (permalink) Old 09-13-2017, 03:16 PM
I removed the metal plates on mine shortly after getting the bike.............had a slide on slush (10-15 mph and about 20') which broke the head off the turn signal and when the whole affair popped out of the fairing it cracked the fairing. It was repairable (almost undetectable) but I would like to shorten the stalks.
Duffy is offline
post #16 of 19 (permalink) Old 09-13-2017, 04:59 PM
Superb. Now you can install it at the depth you want! (20-30 turns of duct tape inside should hold it!)
Kidding aside, it`s amazing what you can do with 3M flexible epoxy.You could stick a plastic plate inside (with suitable hole to hold the stalk). Not perfect, but an occasion like this deserve at least a month of DIY hacking fun (while the new part crosses the pacific..)
dddd is offline
post #17 of 19 (permalink) Old 04-09-2019, 07:21 AM
I just shortened my stalks to get them shorter than my bars. Thanks for this! Hopefully I'll never find out if they're short enough.
boshuda is offline
post #18 of 19 (permalink) Old 04-09-2019, 09:26 AM
Fly-Sig's Avatar
For reference, micro size LED turn signals can be installed. I used R&G Racing brand, though there are other brands out there too. R&G sells an adapter plate. eBay is a source too.
Signal mods are a few posts down in this thread
https://www.kawasakiversys.com/forum...n-signals.html
Fly-Sig is offline
post #19 of 19 (permalink) Old 04-09-2019, 12:12 PM
jaaklucas's Avatar
Clever guy! I dont think the shorter stem affects the visibility of the turn signal much,that would be my first concern. And the metal bracket is redundant ,alot of us have removed it.
jaaklucas is offline
