windscreen mount GPS for 2009: one solution - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 08-10-2016, 02:16 PM Thread Starter
There are limited options for a non-handlebar mount GPS for the 2009 so I made my own - some photos of the mount process below.
We took a piece of steel, cut it to shape and spray-painted it flat black, added some stainless hardware, a ram mount purchased online (Arkon 4-Hole AMPS to 17mm Ball Adapter), a few rubber washers of various sizes, then hard-wired it to the license plate light circuit, adding an inline fuse.
It works very well - no vibration, no obstruction...
revere is offline
post #2 of 7 (permalink) Old 08-10-2016, 02:21 PM
Wow that looks really good, nice job!
zirconx is offline
post #3 of 7 (permalink) Old 08-10-2016, 02:29 PM
Excellent! I was just about to womp up a center mount bracket for a Zumo 550 gps myself. I like yours better (than what I was musing with, in my head, anyway).
Where's a good place to buy those tall rubber cylinders you have there? Are they just rubber stoppers (corks) that have a hole drilled through them? If they are "rubber washers", they are the thickest rubber washers I've ever seen.
Nice work!
trialsguy is offline
post #4 of 7 (permalink) Old 08-10-2016, 02:38 PM Thread Starter
Nice work!
Thanks for the comments - yes, the washers are actually surplus test-tube rubber stoppers (holes easily drilled through)...strangely, I just happened to have a bunch in the garage (https://www.amazon.com/GSC-Internati...857849&sr=1-77)
revere is offline
post #5 of 7 (permalink) Old 08-10-2016, 11:48 PM
....ride like the one-eyed Jack of Diamonds with the Devil close behind...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility, it's right. If it disturbs you, it's wrong until either the machine or your mind is changed."
-Robert M. Pirsig
bcalan is offline
post #6 of 7 (permalink) Old 08-11-2016, 11:42 AM
Very Nice....
post #7 of 7 (permalink) Old 08-13-2016, 10:41 AM
jnor's Avatar
jnor is offline
Tags
2009, gps, versys, windscreen bracket
