Carrying extra gas on the Versys - Kawasaki Versys Forum
Like Tree2Likes
  • 2 Post By twowheeladdict
post #1 of 10 (permalink) Old 05-10-2016, 07:12 PM Thread Starter
bigaussie's Avatar
HI
I have two of these canisters but don't know where to mount them as I have the Givi side cases and top case.
They will each hold a 33 oz / 975 ml MSR fuel bottle.
Any ideas as where to mount them?
Alternatively does anyone have a better solution to carry some extra gas?
I can't see how to mount a RotopaX Gasoline Pack
Thanks in advance.
bigaussie is offline
post #2 of 10 (permalink) Old 05-10-2016, 08:24 PM
I had mine mounted under the side case frames. Looked like exhaust to the laymen.
Lours_Polaire and danibalagan like this.
post #3 of 10 (permalink) Old 05-10-2016, 10:25 PM
if you only ride solo the passenger peg mounts (sub frame) is a good place
post #4 of 10 (permalink) Old 05-10-2016, 10:27 PM Thread Starter
bigaussie's Avatar
Hi twowheeladdict
I looked to do that but I must have a different case frame on the 2007 as I don't have room / the ability to take the top off.
I will have another look tomorrow.
Hi silviefox
How did you mount them? Do you have photos? I will be solo.
post #5 of 10 (permalink) Old 05-11-2016, 08:11 AM
I did this same thing, but I have the smaller Givi side bags. I zip tied the canisters to the side bag frames. The zip ties went through the holes in the canisters molded in brackets. Yes, it was a little tricky to spin the tops off the canisters when mounted in this spot. But the zip ties have a little "give" to them, so you can "shift" the canister a bit while turning the lid on or off. When mounting this way, it makes good use of what is otherwise wasted space.
trialsguy is offline
post #6 of 10 (permalink) Old 05-11-2016, 08:50 AM
Originally Posted by bigaussie View Post
Hi twowheeladdict
Hi silviefox
id use hose clamps to mount them personally. and i dont have mine mounted due to not riding solo all the time
post #7 of 10 (permalink) Old 05-13-2016, 07:14 PM Thread Starter
bigaussie's Avatar
Hi twowheeladdict
I think I have the space, but not the access because the turn indicators were relocated to that space when the bags were mounted.
I will see if I can move them again.
Could you please post a larger / clearer picture of your rear-end, esp. the turn indicators?
Hi silviefox
My friendly mechanic advised against the rear footpeg location as they could bite my leg in case of a spill.
Alan
post #8 of 10 (permalink) Old 05-23-2016, 11:26 PM Thread Starter
bigaussie's Avatar
I am now designing some brackets to bolt onto the topcase rack.
They will have to be custom fabricated.
I have mocked them up soft metal (old angle bracket and aluminium bar) but they will need to be 3/4" or 1" mild steel and painted or powder-coated black.
post #9 of 10 (permalink) Old 05-24-2016, 05:45 AM
Hi twowheeladdict
Alan
Sorry I didn't see this sooner. The photo I posted was the best I could find when I looked. Bike is gone so can't take new ones.
post #10 of 10 (permalink) Old 05-24-2016, 08:14 AM Thread Starter
bigaussie's Avatar
No worries.
I have since worked out that even with the indicators removed I don't have the space, but with the help of a friend have designed two brackets to attach them to the top box rack.
