Learning from BAD Experiences - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 08-28-2010, 12:49 AM Thread Starter
WannaRideVersys's Avatar
Exclamation Learning from BAD Experiences
Okay, so last night I had a CFI (Certified F*****G Idiot) moment. First the warning- DO NOT USE GOOF OFF ON ANYTHING YOU LIKE!!! I have used this product on about everything I like with no issues whatsoever, until last night.
After flipping my windshield over on the '09, I noticed that my Kawasaki sticker was upside down, and backwards, of course. I peeled the sticker off, and there was of course, the leftover 'goo' that stickers leave behind. I went for my trusty can of Goof Off to remove the remnants. On the first spay, I should have known something wasn't right, as the solution trickled down and away from the goo- typically, Goof Off will sit and soak into the leftovers. I sprayed again, grabbed a micro fiber cloth and began wiping away. Immediately I noticed that the wiping felt a bit rough compared to prior applications, then I noticed how the solution had all but melted the finish on my windshield! I couldn't believe what lie before my eyes. My windshield was completely ruined, with no sign of clearing up. The only plus side to this matter is that I have finally made up my mind to replace the OEM windshield wit a Givi. I hope the wind deflection of the Givi is half as good as others have posted here.
Lesson well learned- if in doubt, scrub with soap and water.
'09 Greener
Ride on. Ride hard. Respect the bike.
WannaRideVersys is offline
post #2 of 7 (permalink) Old 08-28-2010, 02:17 AM
Rik
Rik's Avatar
WD40 is the ticket for sticker and decal residue
Rik is offline
post #3 of 7 (permalink) Old 08-28-2010, 02:55 AM
Know how you feel, had a dumb moment on my shark rsx helmet, used a bit of loctite to try to glue a plastic ring thing that had broken small tabs on visor, left it over night and it had eaten through the visor and made it brittle, $140 NZ to replace visor.
post #4 of 7 (permalink) Old 08-28-2010, 05:49 PM
MrCrappieKiller's Avatar
Did the same on my stock windshield. I ended up painting the bottom half black, where the Goo Gone had messed it up. Doesn't look to bad.
MrCrappieKiller is offline
post #5 of 7 (permalink) Old 08-28-2010, 06:15 PM
Not to worry, I'm more certified than all ya...Thought debadging my windscreen would go much better with (drumroll please) "Acetone". Really, really a bad idea.
But that's how I decided a Givi
contractor is offline
post #6 of 7 (permalink) Old 08-28-2010, 08:10 PM
Nytrydr's Avatar
Flipped stock wind screen. removed sticker with heat gun and cleaned with W-D40
Nytrydr is offline
post #7 of 7 (permalink) Old 08-28-2010, 09:04 PM
I fucxed up too the same way.
However think made some lemonade from this lemon.
Blacked it black, flipped it upside down and good to go with the Givi. Less turbulance, I think.
First time put it on.
Or just paint it black and flip it upside down. Looks good but might not give the wind protection you want.
Element's setup is also
http://www.kawasakiversys.com/forums...dscreen&page=5
2 guys looked out their jail cell window,
1 saw the mud and the other the stars.
