Getting ready to tour the V, some minor mods - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 08-25-2010, 07:44 PM Thread Starter
JakeSabre's Avatar
These first 2 pics are of the old mirrors and then the new mirrors with the Cycra ProBends, I liked the way Roadstergal's looked, I ended up cutting them up a little, setting them closer to the levers. The mirrors I thought might be too small when I unboxed them, also, I thought the wind would blow them around, they're a little too easy to adjust. I got lucky, the handguards actually knock the wind off of the mirrors, and they are not too vibrated to see, so they can stay.
Mirrors = $70
Cycra ProBends = $40
Jake Sabre
2009 Kaw Versys
40 years riding, 2 years MX racing
20 bikes owned over time, 3 MC shops worked at
Couldn't live without 2 wheels and a motor
JakeSabre is offline
post #2 of 10 (permalink) Old 08-25-2010, 07:51 PM Thread Starter
JakeSabre's Avatar
Next three pics include my toolkit that originated with my 1993 Honda XR650L, then I carried on a Honda Shadow Sabre, then a Harley Dyna Wide and now the V. It fits in the bottom of one of the Givi 21s.
Next is the homemade radiator guard, I found some decorative-type steel mesh at a metal fab shop, cut it to size, put a crimp bend on top and 2 lower bolts hold it on.
Next are the HD passenger footpegs I had mounted on a scooter, took 'em off and they fit perfectly, solidly mounted, they hold the weight of my legs as they are fully stretched out.
Radiator guard: $20
Hiway pegs: $0
Next project: from a $15 KTM front fender, make a front fender extender, and a rear hugger.
AND...thanks to all the folks here that I got the inspiration and get-up-and-go to get these farkles done!
Jake Sabre
2009 Kaw Versys
post #3 of 10 (permalink) Old 08-25-2010, 07:58 PM
Looks good!! Where you headed??
post #4 of 10 (permalink) Old 08-25-2010, 08:06 PM
blipco's Avatar
Minor mods but necessary mods.
blipco is offline
post #5 of 10 (permalink) Old 08-25-2010, 08:11 PM Thread Starter
JakeSabre's Avatar
I might run out to Big Bend for a shakedown run, take I-10, see what kind of time I can make with this 5 gal tank...love it.
Jake Sabre
2009 Kaw Versys
post #6 of 10 (permalink) Old 08-25-2010, 08:57 PM
Good job, especially on a budget!
What mirrors are those? My left one is usesless, just swings around, and I have to replace them anyway.
Roadstergal is offline
post #7 of 10 (permalink) Old 08-25-2010, 09:17 PM
+10 and on your tour.
ride safe and be safe.
post #8 of 10 (permalink) Old 08-25-2010, 09:21 PM Thread Starter
JakeSabre's Avatar
Yeah, I'm always on the budget, one of the reasons I love the V, its value is hard to beat...
The mirrors are some kind of cheap bar end mirrors, I dont think I would recommend them.
On the stock mirror, separate the top, alum looking nut off of the bottom, black one, then use a 10mm socket to tighten the small nut up inside the mirror tube, snug but not locked down. After reassmbly, always rotate the mirror clockwise to keep this hidden nut tightened.
Jake Sabre
2009 Kaw Versys
post #9 of 10 (permalink) Old 08-25-2010, 09:51 PM
CJBROWN's Avatar
I've been looking high and low around here for a piece of sheet metal like that to make a guard. Nothing so far, will keep looking.
Like it so far, also like the idea of making a fender extender. The $42 one is cute, but gee, really? Even a piece of hard neoprene rubber would work.
Keep posting.
EDIT: BTW, I did the stock mirror fix as you describe, a couple of rides ago, and they worked perfectly. Still some vibes tho.
Chris Brown
In SoCal
CJBROWN is offline
post #10 of 10 (permalink) Old 08-26-2010, 06:59 AM
djg
You might try remounting with blue Loctite, you have to get to the nut up inside the base. Mine did the same thing, I have had no problem since using Loctite. There are threads here on this.
djg is offline
