Fender Options - Kawasaki Versys Forum
LinkBack Thread Tools
Old 08-18-2010, 03:04 PM Thread Starter
camaroz1985's Avatar
Fender Options
I know it has been discussed a lot on the forum, but I am looking at options for a high mount front fender. First, I'll admit it is mainly for looks. I have the OE tires at the moment, and even if I change to a taller dirt oriented tire as I intend to do when these wear out, I can just raise the stock fender a litte. I just like the looks of the ones I have seen done.
I will be leaving the brake lines as they are until I wear out the first set of pads, then I will get dual lines from the master cylinder to the calipers. Also with any option I will be addressing fork protection in some way, and that is part of what makes my options different.
First is the easiest, just moving the stock fender up to the lower triple clamp. This has been done as seen in this picture from MountainMan.
I think it looks pretty good, its the cheapest method, but not quite what I am after.
Next is the common Acerbis SuperMoto fender as seen on the bike of Thumper (among others)
I like this a lot, and it would be fairly cheap to do. I would probably replace the PVC fork guards with some KX fork guards as done by Trailslapper
and chop the tip off to make it a little bit sleeker as done by a lot of people on the supermotojunkie forums a la this picture:
Now I saw another post on the boards where someone was questioning a Buell Ulysses front fender setup. This intrigued me a lot, and after looking at them, would provide good protection, as well as the look I want. Here is a picture on the Buell.
I did a quick MSPaint photo chop to see what it would look like on the Versys, and came up with this.
I think it looks nice, maybe the angle of the upper fender needs tweaked a little bit. So get some Buell parts and away I go, right? Well not that easy. There don't seem to be many secondhand parts available, and the parts from the dealer would be about $280, while they last (some have been discontinued).
I put out some feelers on Buell boards as it seems people with Ulysses sometimes replace the fender system with a conventional one for touring, but I haven't had any hits yet.
I did get someone respond saying they had a Buell STT fender setup for sale (and very reasonable), and it is on its way to me now. It is the same upper "beak" fender, but with conventional fork protectors.
I will need to make an adapter bracket for the fender mount, but that is not a big deal. In the mean time I will continue looking for a Ulysses lower fender.
So, what do you think? Like the look? Seem like too much effort?
Hopefully will have real pictures within a week or so.
camaroz1985 is offline
Old 08-18-2010, 04:14 PM
Can't give a picture, but some have added a motocross type high fender (all of it), and left the stocker in place (painted black) ala BMW and Ducati.
Old 08-18-2010, 04:28 PM
Thumper's Avatar
I thought about chopping the tip too. I could not find a pic of one that had been done. That is sleek! Now I have something else to think about.
Sounds like you are putting a good plan together. Can't wait to see the final setup. Did you try "Bad Weather Bikers" as a Buell site. My wife is a member on that and they are very active.
I like the Photoshop work too! Pretty cool.
IBA #23562
Thumper is offline
Old 08-18-2010, 07:51 PM
glowcat13's Avatar
I think if you use the acerbis up top and the buell part for the forks and rear it would look cool.
glowcat13 is offline
Old 08-18-2010, 09:48 PM
Nytrydr's Avatar
Looks like MountainMan has some nice clamp on the fork legs holding his fender.
I would use the black acerbis SM fender I think thats the KTM SM fender as they use acerbis plastic its like $21 dollars at KTM World.com. I would leave the stock fender, raised if using larger tire or even better the v-strom 19 inch wheel.
Nytrydr is offline
Old 08-18-2010, 11:39 PM
kevinw9's Avatar
I think your asking for problems unless you relocate the brake line that crosses from one side to another(first pic). Mud on the tire, a stick that follows around with the tire may rip that brake line apart. Just get a longer cross over brake line, and your done. Still a cheap mod.
kevinw9 is offline
Old 08-19-2010, 10:56 AM Thread Starter
Thanks everyone for the responses.
I have seen that too. I would entertain that idea, but would get another fender to start with, as I want this to be reversible. Here is a picture I found from aleeoop.
I have a post on Bad Weather Bikers, BuellXB, BuellForums, and ADVRider. I'm hoping somewhere I will find the Ulysses lower fender.
That's another thing I was thinking about. I'm getting the Buell upper, but if I don't like how it looks I will just get the Acerbis, its cheap enough.
That isn't my bike, but I understand what you are saying. That was another reason I like the Buell lower fender, it still provides protection to the brake lines and from things flinging up into the radiator.
Old 08-19-2010, 11:03 AM
Nytrydr's Avatar
If using clamps on the fork tubes, like MountainMan, be sure not to over tighten them in the area of fork travel. the internal parts may not like it if this section of the tube is squeezed or distorted. Another reason to make sure when tightening the upper and lower triple clamps to follow the manufacture torque spec for each. The top clamp is usually tighter then the lower as the fork internals do not travel into that area.
Also, I don't think the fender is strong enough to do this but if clamped to the fork improperly, it may cause a binding effect on the fork or if done right it might act like a fork brace, that would be a good thing if needed.
Donn
Nytrydr is offline
Old 08-19-2010, 12:00 PM
buffamazon's Avatar
Send a message via Yahoo to buffamazon
I do like the low cost option of leaving the stocker in place and painting it black, with the Acerbis up top. Anyone who has done this, did you just rotozip the stocker to remove the front portion?
NICE photoshop work!
09 Versys In Go-Fast Green
Acerbis Pro Pack Handguards
Ogio Tailbag
Ogio Saddlebags
Vortex 44T Sprocket
Wolo Bad Boy Air horn
Trackside 12 volt power adaptor
buffamazon is offline
Old 08-19-2010, 05:17 PM
Nytrydr's Avatar
I like that one too, but I don't think the top fender is the SM fender. I would use the SM fender, think it looks better, its more aerodynamic and is made for the smaller wheel size.
Nytrydr is offline
Old 08-24-2010, 11:37 AM Thread Starter
I should have the upper fender and STT fork guards tomorrow. Wouldn't you know it the day I paid for them I had someone email me about Ulysses lower fender. Working out a deal on that now, so I should have the whole setup shortly.
Old 08-26-2010, 12:30 PM Thread Starter
STT parts got here yesterday.
I haven't installed them yet (the Ulysses parts will be here next week). I did hold them up to see what it would look like.
I think it looks good. I still think I will like the Ulysses lower better, but the fork guards look great too. What do you guys think?
Old 08-26-2010, 05:30 PM
Thumper's Avatar
Looks good to me! Kind of hard to tell in the pic, but as long as they will cover the fork well, your good to go man.
IBA #23562
Thumper is offline
Old 04-21-2011, 10:36 PM
CopyCat's Avatar
[SNIP]
Where are the final photos??
CopyCat is offline
Old 04-22-2011, 12:21 PM Thread Starter
Still waiting on fork clamps so I can fab up some brackets. I ordered them the beginning of November and they are on back order. They are supposed to be restocked today, but I've heard that before
Old 04-22-2011, 06:11 PM
Try these folks: http://www.fastfromthepast.com/servl...mps/Categories
They're finished a lot nicer than the Pro-Tek ones.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
Old 04-22-2011, 07:20 PM
I have aSM fender. I just cut 4 holes in the flat part of the fender and used zipties to secure it. With black zipties going over the lower tripple you cant even see them.
08' Versys
HAWKSHOT99 is offline
Old 04-25-2011, 11:19 AM Thread Starter
I thought of that, but I have the Ulysses fender which isn't long enough to do that, and I want to make a bracket that could mount fog lights with the fender.
Thanks for the link ttpete. I will look into them if the Protek's don't show up soon, though they are $30 more shipped than the protek's.
Old 08-18-2011, 05:10 PM Thread Starter
Finally I should have the Pro-Tek fork clamps tomorrow. I ordered them November 6, 2010!!
Old 08-18-2011, 05:32 PM
stagehand38's Avatar
"Building the perfect beast"
...gotta love it!
stagehand38 is offline
