Some more Farkle's - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 04-04-2016, 06:34 PM Thread Starter
Stoley's Avatar
Some more Farkle's
So I wasn't sure if this was supposed to go under performance or cosmetics but here's my new temp gauge, cell phone holder and USB port.
I bought the USB port off of Amazon hooked it up and noticed that it has a blue LED light running all the time. Should I be concerned that this may drain down the battery? Or should I put an in-line switch on it does anybody else run USB ports and what kind do you have?
Stoley is offline
post #2 of 5 (permalink) Old 04-04-2016, 07:09 PM
you should run it all thru a relay so its switched power and you dont come out to a dead battery
post #3 of 5 (permalink) Old 04-04-2016, 08:07 PM Thread Starter
Stoley's Avatar
Physically add a relay or tap into a switched wire?
Stoley is offline
post #4 of 5 (permalink) Old 04-04-2016, 09:04 PM
BKP
BKP's Avatar
You should tap into a switched wire. Silvie's correct... even a small residual drain can kill your battery if you're not riding for a few days. Learned that the hard way a few years ago, with a power outlet (and it didn't even have a visible source of drain).
There's an easy source up front on the '15, '16, and I've installed both a gear indicator, and power plug - both switched. Don't know where you'd find it on your pre-'15 bike.
In the past, I've used Eastern Beaver products. The Versys doesn't have much room for a full fuse block, however, their 3-fuse (all switched) solution fits anywhere. His products are solid. Here's the link:
3 Circuit
Ride safe...
Barry
2015 Versys 650 Pearl White
[space holder for farkles...]
BKP is offline
post #5 of 5 (permalink) Old 04-04-2016, 09:24 PM
add a new relay and use a switched wire (parking/marker lights) to trigger it heres a write up of how i did mine
http://www.kawasakiversys.com/forums...ects-come.html
