Trimed up the rear fender today - Kawasaki Versys Forum
Like Tree2Likes
  • 1 Post By BKP
  • 1 Post By silviefox
post #1 of 13 (permalink) Old 04-02-2016, 12:12 PM Thread Starter
Trimmed my Fender on my 2012 versys, not a huge fan of the huge plastic piece. I wanted to see how this looked before I bought a fender elimator and I think I will keep it this way for a while. Only took about 10 mins.
12Versysphantom is offline
post #2 of 13 (permalink) Old 04-02-2016, 12:25 PM
mine is trimmed down like that aswell, i like it more then a tidy tuck
post #3 of 13 (permalink) Old 04-04-2016, 11:01 PM
BKP
BKP's Avatar
Nice... have you ridden in the rain yet?
saddlebag likes this.
Ride safe...
Barry
2015 Versys 650 Pearl White
[space holder for farkles...]
BKP is offline
post #4 of 13 (permalink) Old 04-04-2016, 11:25 PM
i have loads, (yay portland) and that litle tip isnt missed
post #5 of 13 (permalink) Old 04-04-2016, 11:41 PM
BKP
BKP's Avatar
That's good to hear... Been thinking of trimming it up myself, but don't relish the wet streak down the back in the rain...
Ride safe...
Barry
BKP is offline
post #6 of 13 (permalink) Old 04-05-2016, 08:33 AM
Stud Muffin's Avatar
Looks good. Is it me, or does the tire in the "after" picture look like it's wearing a flat spot in the center. Do you do a lot of straight line highway riding??
Stud Muffin is offline
post #7 of 13 (permalink) Old 04-05-2016, 10:33 AM
Yes, I like the look a lot also. Not to hijack the thread, but is there anything you can do (I know go canyon carving as often as possible) to slow down the tire wearing the flat spot in the middle? I would think in reality most of us do something like 80% of our miles in a straight line.
cjcintucson is offline
post #8 of 13 (permalink) Old 04-05-2016, 06:08 PM
Originally Posted by cjcintucson View Post
...Not to hijack the thread, but is there anything you can do (I know go canyon carving as often as possible) to slow down the tire wearing the flat spot in the middle? I would think in reality most of us do something like 80% of our miles in a straight line.
Chuck - try riding on some dirt roads.
Should reduce the flat-spotting....
post #9 of 13 (permalink) Old 04-07-2016, 11:09 PM
How does it look at the point where you cut it? What did you use to cut it? Thinking about doing this to mine as well
Chappssss is offline
post #10 of 13 (permalink) Old 04-08-2016, 09:31 AM
Do you have any pictures? (Front and Back). What was your method of cutting it?
post #11 of 13 (permalink) Old 04-08-2016, 09:54 AM
mines trimmed right above the bottom of the license plate (so the plate covers the cut line) just used a pair of tin snips. will put up a pic later
post #12 of 13 (permalink) Old 04-11-2016, 01:28 PM
I kept getting my thumb caught by the 'tail' when I took my '15 V off the rear stand, so I decided to remove 1.5" of it, leaving it looking 'stock', but shorter.
First step - I 'drew' a line across the tail under the license bracket and measured how long it was from the plate to the bottom - 4".
Then I removed the license plate and put a piece of 1.5" masking tape across it, from the 'line' I drew DOWN, then cut that 1.5" off below the tape.
Next up was to cut a piece of 1" stainless steel to the width of the flatter part of the OEM tail, then drill four 1/8" holes into it. Wider apart at the top because the tail's wider up there.
Then I held the SS bit I'd made to the cut-off portion w/ vice-grips, then continued the 1/8" hole thru the plastic
and then pop-riveted it.
Held it against the upper part of the tail, then drilled two more 1/8" holes
and added two more pop-rivets.
Once the license plate is bolted back on, everything is hidden, it looks "stock", and SO FAR has NOT caught my thumb again, and HOPEFULLY I won't have added a stripe up my back in the rain.
TOTAL co$t - about 10 cents for the pop-rivets!
post #13 of 13 (permalink) Old 04-11-2016, 01:41 PM
saddlebag's Avatar
And you got to keep that awesome reflector! Nothing like a last line of defense if the texting moron in the bus quickly approaching your six at the stop sign gazes up. That'll get his attention!
saddlebag is offline
Tags
fender eliminator
