Quick answer sneeded - Happy Trails Engine Guard - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 08-08-2010, 12:42 AM Thread Starter
tenover's Avatar
About to pull the trigger on a Happy Trails Engine Guard http://www.happy-trail.com/Kawasaki%...e%20Guard.aspx
Do I need to purchase one or two? Just wondering if "1" includes both sides? Thanks.
EDIT: That goes for the HB guard as well...I may go that route. Do I need to order one or two? Gracias.
EDIT #2: I just read a post that sais the HB guards do not fit on the CA models unless you slice up the CA emission canister cover??!??! WTF? Is that still the case or have they modified the guards since then?
tenover is offline
post #2 of 3 (permalink) Old 08-08-2010, 01:33 AM
bigaussie's Avatar
I THINK the Happy Trails is the guard that blocked the oil plug - i.e. you have to remove it to change the oil.
They may have redesigned it by now
bigaussie is offline
post #3 of 3 (permalink) Old 08-08-2010, 04:19 PM
When you order quanity of "1", you will get the complete set. The happytrail does interfere with the drain plug and others have made mods for the H&B. Any pics from members doing such?......
2009 Lime green Versys
Hepco & Becker crash bars
Givi side carriers w/ E21's
Fenda Extenda
cut tail fender
black lower panels
Sw-Motech 20mm riser
Randy49 is offline
