Cheap Alternative for skid plate for versys - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By fijiman
post #1 of 9 (permalink) Old 03-07-2016, 03:11 PM Thread Starter
I have a 2011 versys and was wondering if there is a cheap alternative to getting a skidplate. I already have H&B engine guards and just saw their skid plate, but they are for 2015 model and upÖ.and besides itís really spendy. Any cheap alternative?
Thanks!
fijiman is offline
post #2 of 9 (permalink) Old 03-08-2016, 09:36 AM
kohburn's Avatar
since the versys doesn't have a frame under the engine there really are no cheap skid plates
kohburn is offline
post #3 of 9 (permalink) Old 03-08-2016, 03:01 PM Thread Starter
Got it, just ordered the one from Thiland....will see how it pans out... thanks!
fijiman is offline
post #4 of 9 (permalink) Old 03-08-2016, 05:07 PM
JACoH's Avatar
I just bought some aluminum strap, 1/8" x 2", at Home Depot and cut to fit, attached to each side plastic lower fairings, in front of oil drain plug. Doesn't really protect anything like a rock guard, but small objects would hit it before the drain plug casting.
JACoH is offline
post #5 of 9 (permalink) Old 03-08-2016, 06:05 PM Thread Starter
That sounds cool....Do you have any pictures?
kawdog likes this.
fijiman is offline
post #6 of 9 (permalink) Old 03-10-2016, 12:19 PM
Another solution - get the pan from a "late-model" - the oil-drain comes out the left-side INSTEAD of a "tit" hanging down the bottom....
post #7 of 9 (permalink) Old 03-11-2016, 10:38 AM
JACoH's Avatar
Here are pics of my strap, attached to plastic cowls, with rubber grommets and 6 mm bolts.
ID:	82881   Click image for larger version
ID:	82889   Click image for larger version
JACoH is offline
post #8 of 9 (permalink) Old 03-11-2016, 11:31 AM
I would NOT count on that to protect your oil-drain, as a "frontal" hit looks like it will destroy it!
post #9 of 9 (permalink) Old 03-12-2016, 11:02 AM
JACoH's Avatar
Yes, but I figure it would hit it first, rather than the oil drain. It will give me that extra inch to react. LOL. And I needed something to do that day. And, I figure that the angle it is at, aerodynamically, and attached to the plastic wings- if it does get hit, it will pull on the plastic pieces and rotate them at the correct angle to contain any oil that escapes.
JACoH is offline
