Will 07-09 OEM topcase work with 10-14 brackets - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 03-03-2016, 08:55 PM Thread Starter
SpyvsSpy's Avatar
I purchase a Kawasaki OEM topcase and bracket but bought the wrong model year for my bike. I can either:
A. Sell it
B. Have a workshop fabricate me a new bracket using the 07-09 one
C. Buy a 10-14 bracket OEM
D. Buy an aftermarket bracket
My question, if I am going with option C or D, is: Can the 07-09 OEM top case and base plate work with other brackets?
Please let me know since this is bugging the crap out of me right now, thank you
SpyvsSpy is offline
post #2 of 11 (permalink) Old 03-03-2016, 09:41 PM
The OEM cases are made buy Givi so a Givi Rack or another rack with a Givi Adapter will work with the case. (You have the base plate so you should be good to go)
post #3 of 11 (permalink) Old 03-04-2016, 12:09 AM Thread Starter
SpyvsSpy's Avatar
I had no luck finding Givi brackets that look the part...
SpyvsSpy is offline
post #4 of 11 (permalink) Old 03-04-2016, 11:19 AM
http://www.twistedthrottle.com/givi-...-versys-650-10
as fitted to my 2012
post #5 of 11 (permalink) Old 03-04-2016, 11:59 AM
Is it a Monokey or Monolock top case????
post #6 of 11 (permalink) Old 03-04-2016, 12:56 PM Thread Starter
SpyvsSpy's Avatar
It says monolock on the base plate. I wonder if http://www.giviusa.com/my-motorcycle...idearms-detail will work with what I have
SpyvsSpy is offline
post #7 of 11 (permalink) Old 03-04-2016, 09:01 PM Thread Starter
SpyvsSpy's Avatar
The pictures provided show where the Gen 1 versys bracket bolts to the base plate. My question is if the base plate can be used on either the gen 1 or gen 2 setup
ID:	81945   Click image for larger version
SpyvsSpy is offline
post #8 of 11 (permalink) Old 03-05-2016, 03:57 PM Thread Starter
SpyvsSpy's Avatar
Is there any way that you can measure the distance between each bracket where the base plate bolts to?
SpyvsSpy is offline
post #9 of 11 (permalink) Old 03-05-2016, 11:49 PM
Makes no difference to the rack, only the base plate
post #10 of 11 (permalink) Old 03-05-2016, 11:51 PM
Yep
The end of the tape is over the centre of the mounting bolt hole
post #11 of 11 (permalink) Old 03-06-2016, 03:52 PM Thread Starter
SpyvsSpy's Avatar
Yep
So those two bolts are the same as these?
SpyvsSpy is offline
