Gauge swap - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By MaverickAus
post #1 of 8 (permalink) Old 02-22-2016, 09:50 AM Thread Starter
Gauge swap
I will be picking up a wrecked '12 Versys and it will need a few parts including the gauges. It appears the gauges are digital and analog, does anyone know if these are both run electronically or if the speedo is run off a cable? The speedos ratio if cable run?
If both are electronic has anyone done a gauge swap from another bike? At this time im just looking to get the bike in rideable condition and dont want to spend $100+ for a cluster.
borjawil is offline
post #2 of 8 (permalink) Old 02-22-2016, 10:03 AM
all electric
post #3 of 8 (permalink) Old 02-22-2016, 10:44 AM Thread Starter
all electric
Thanks silverfox. Anyone know of donor gauges from other bikes that work? Might just have to use my phone as a speedometer...
borjawil is offline
post #4 of 8 (permalink) Old 02-22-2016, 10:57 AM
i beleave the er6n one will fit, @jdrocks would know
post #5 of 8 (permalink) Old 02-22-2016, 01:18 PM Thread Starter
Just had a thought. Havent worked a ton with electronic gauges. Are there ratios for electronic gauges or could i wire up a universal speedo to the bike? Something like this? I can make a mount all day, just not sure how the wiring part and speed reading is done
Motorcycle Odometer Speedometer Tachometer Gauge RPM 15000 Universal LCD Digital | eBay
borjawil is offline
post #6 of 8 (permalink) Old 02-22-2016, 01:29 PM
If you download the service manual on this site it tells you the wiring for the instruments. The instruments that you buy should tell you what wire does what. You then just have to match them up. I know it's been done try a search of the site for manual and more info.
silviefox likes this.
post #7 of 8 (permalink) Old 02-22-2016, 02:18 PM
There's an aftermarket gauge-cluster that some have installed, but I haven't.
post #8 of 8 (permalink) Old 02-23-2016, 09:01 AM Thread Starter
Well Ill have to look into some of the cheaper knock offs and report back. May be a while wont have the bike for a couple weeks.
borjawil is offline
