2015 OEM 47L Rack bracket & Base plate - Kawasaki Versys Forum
Like Tree7Likes
  • 1 Post By Slodirtgirl
  • 1 Post By turn8a
  • 2 Post By kawdog
  • 1 Post By turn8a
  • 2 Post By kawdog
post #1 of 13 (permalink) Old 01-29-2016, 06:51 PM Thread Starter
Slodirtgirl's Avatar
I looked for pics on real bikes before I bought this and found very few so maybe this could help someone who may be on the fence.
I have no intentions to mount a top case but for just a general rack/ holding camping gear. I got it at a great deal. So it was more inexpensive than any other general purpose rack I saw and looks good when not I use.
It was fairly easy to set up, I am not terribly handy so it took me about 45min, should be more like 30min-ish. Instructions were good and had pictures!
I did notice it had some washers that allow some movement of the base plate/ rack. I talked to someone a bit more knowledgeable and they said it seems to be designed to move it bit. Hmmm... Anywho, thought I would share.
Slodirtgirl is offline
post #2 of 13 (permalink) Old 01-29-2016, 07:21 PM
The OEM Cases are made by GIVI
post #3 of 13 (permalink) Old 01-29-2016, 07:49 PM
Looks good. Why don't you want to mount a top case? They come in a lot of different sizes and are easy to put on and take off.
turn8a is offline
post #4 of 13 (permalink) Old 01-31-2016, 07:54 AM
Thanks for the photos. I was worrying about the SW-Motech rack but it seems to have the same footprint as the Givi rack and the SW-Motec adapter plate sits above the rack like the Givi rack. However it seems that the Givi rack has an extra aluminium layer between the base plate and the plastic adapter plate.
I had a problem with the SW-Rack as when it was fitted (I did not fit it) one the right rear bolt into the grab handle stripped the thread so I encountered tortional stress. I am about to re-thread with a HeliCoil as I need to use a specific size bolt because of the spacers required for the side rack mounting point. If that does not work I will have to replace the grab handle which is not cheap so make sure you apply the correct torque setting and use a thread locker fluid.
I think that alternate suppliers such as Touratech are stronger but are a lot more expensive for both rack and top box.
AdamG is offline
post #5 of 13 (permalink) Old 01-31-2016, 08:37 AM
I could see that happening . I mounted a sw aluminum top rack to my
2015. It was a tight fit. But I had no problems with the mounting .I used the givi adapter plate "mono lock " from my 2008 versys with no problems.
AdamG likes this.
turn8a is offline
post #6 of 13 (permalink) Old 01-31-2016, 11:34 PM Thread Starter
Maybe someday, right now with the camping setup I have it works best to have no luggage there. It works perfect to stack and extend the gear I need.
post #7 of 13 (permalink) Old 01-31-2016, 11:59 PM
kawdog's Avatar
Your bike looks good and almost built around your Givi bags: they blend in so nice. If the saddlebags do the job alone, then I would not add more wind blocks with an additional trunk unless you need it. Your only problem now will be cars in front of you hitting their brakes because you look like a cop cycle.
What kind of wheel rim reflectors are those? TIA
AdamG and Slodirtgirl like this.
kawdog is offline
post #8 of 13 (permalink) Old 02-01-2016, 11:56 PM Thread Starter
Thank you for the compliment. I really dig this bike. I plan a few mods here and there but nothing to take away from the bike.
The graphics I got of Ebay from cgd_graphics on eBay
It was a pack, to make 4 stripes on each rim but I liked the look of just 3. I had extra and added some to my squidly dark helmet.
I am happy with the decals. They look good, reflect well and went on easy. I have only had them on 5 rides or so, so time will tell how durable they will be with some seasons on them.
post #9 of 13 (permalink) Old 02-02-2016, 01:07 AM
I chose the SW-Motech rack and Pannier frames for three reasons:
(a) the flexibility in obtaining adapter plates to mount a variety of boxes from different manufactures. I run SW-Motech, Hepco & Becker and Givi
(b) They have adapters for the rack for mounting a tank bag and an wide extension plate for soft or roll luggage.
(c) The side pannier frames can be removed in 30 seconds so you don't have to travel around with the frames when the side panniers are not mounted.
However, they do have a restriction on the weight on the rack but I don't know anyone who follows the manufactuers restrictions.
AdamG is offline
post #10 of 13 (permalink) Old 02-02-2016, 05:20 AM
You have that right.Brought back memories.I remember strapping a 1/4 keg on the back rack on my friends Honda 550 four in the 70's.
AdamG likes this.
turn8a is offline
post #11 of 13 (permalink) Old 02-02-2016, 04:45 PM
kawdog's Avatar
I like the artistic 3, instead of 4 stripes. It looks cleaner, clearer, and hides any alignment imperfections inherent with installing the rim sticker pieces.
May I steal your idea, if my 3m 1/4" 50' roll does not work out? I have a roll installer on the way too to help remove any skill level I don't have :-) At least this time I've got my front and rear pitbull stands to help out installing them.
And don't clean your wheel with WD40! It is easy, but will dry your plastic wheel stickers out (solvent). I'm going to the auto store and may (?) get wheel cleaner for clear coated mags, but soap, water, and a rag may work as well too (if it costs too much.) Some reviews seem to indicate the wheel brushes just flick dirty fluid in your face and the mild wheel cleaners do not do any more than soap, water, and a rag.
Your bike looks perfect red spring and all. Drive Safe!
onewizard and Slodirtgirl like this.
kawdog is offline
post #12 of 13 (permalink) Old 02-03-2016, 10:42 AM
Originally Posted by kawdog View Post
...And don't clean your wheel with WD40! It is easy, but will dry your plastic wheel stickers out (solvent)....
I've been cleaning the wheels on my '08 w/ WD40 for 7.5 years, and (SO FAR...!) none of my wheel 'stripes' have dried out.
Here's my wheel stripes last Thursday....
post #13 of 13 (permalink) Old 02-05-2016, 11:09 AM
Would you mind posting pictures without the side cases? I got the regular ABS model and thinking of adding the top box rack but it's hard to tell what it will look like because I've only seen it on bikes with side cases
Chappssss is offline
