LED driving lights for 2014 650 - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By Curtis
post #1 of 7 (permalink) Old 01-27-2016, 06:47 AM Thread Starter
Does anyone know if the 2015 OEM lights mount on a14? Is there a mounting bar under headlight in the same place? https://www.kawasaki.com/Accessories...BFFA/999940487
Other (non home made) options include the SW motech SW-MOTECH Auxiliary Light Mount Kawasaki Versys 650 2010-2015 - RevZilla and the Denali Denali Auxiliary Light Mount Kawasaki Versys 650 2010-2014 - RevZilla
clay_shooter is offline
post #2 of 7 (permalink) Old 01-27-2016, 11:07 AM
Lours_Polaire's Avatar
Interesting info on led aux. driving light here
LOP
Lours_Polaire is offline
post #3 of 7 (permalink) Old 01-27-2016, 07:39 PM
2linby's Avatar
I just added the Denali mounts from RevZilla. They are easy to mount and stout as hell. Also significantly cheaper than the stockers. You can then add any light you want. I mounted an ole set of Hella FF50's that I am using just as DRL's not spots or fogs and replaced the H7 bulb with an LED aftermarket bulb.
COG# 5539
IBA# 15034
Team Oregon MC Instructor
"2linby" Get it? "Tooling by"
"Everything is simple, nothing is easy".
2linby is offline
post #4 of 7 (permalink) Old 01-27-2016, 08:51 PM
I might have the SW Motech mounts for sale soon. Should know by Saturday evening.
here they are on my bike.
post #5 of 7 (permalink) Old 02-15-2016, 04:57 PM
DarrenVS's Avatar
I'm 99% certain that the new 2015 LED light bar won't fit the 2010-2014 model. The 2015 has a horizontal bar under the nose plastics which isn't there on the older model. The lights are made by PIAA and are their reflector facing technology led range.
They are an expensive option on the mark 3 , but mine came as part of the deal when I bought the bike in November. They are brilliant lights though throw a really good spread of light on the road
DarrenVS is offline
post #6 of 7 (permalink) Old 02-15-2016, 10:35 PM
binderline's Avatar
I just finished up installing the Mondomotos MM10s. Could not be happier. Check out this thread for details: http://www.kawasakiversys.com/forums...ce-please.html
(Thanks again to Onewizard for the great info and advice!)
ID:	80921   Click image for larger version
ID:	80929   Click image for larger version
ID:	80937   Click image for larger version
Binderline
binderline is offline
post #7 of 7 (permalink) Old 04-05-2016, 06:16 PM
Due to a near miss from a driver pulling out on me, I decided I needed to be more ‘visible’. If I did this right, there should be pictures of my ‘fix’ here (the 'sunset' picture was an upload test).
Based on a “webBikeWorld” review (OZ LED Mini Trail Lights Review - webBikeWorld), I selected the “OZ” lights - - sort of. As “wBW” suggested, these lights are offered by multiple sources under different brands. Instead of spending $49.50, I got them on “Amazon” for $22 under the “TMH” brand. Since “wBW” warned of a ‘sloppy’ two piece base, although it has been improved, I made it a one piece by gluing it with one of the many high strength bonding agents out there (black “Geocel” 4500 in this case).
Since my 2014 was prewired for accessories, I decided to use it. I just needed a relay. Rather than adapt some sort of standard 12V relay, I wanted to go with the “Kawasaki” part (an “Omron” 27002-1086) which is used on many bikes. I got one off of “Ebay” for $9, instead of paying about $30 at the Dealer. And, it worked fine.
Now, time for mounting. After considerable head scratching, I went with the mounting as shown in the photos. Thought this was the cleanest, simplest, and most attractive that still provided good function. I drilled small mounting holes in the plastic, but these can be easily hidden (black plastic fastner? Decal?) if the lights were ever removed. The plastic in this area is very solid. And, I’m not concerned about a bit of vibrating light because I think it contributes to making me more visible.
The wiring was straight forward. The connection/relay was hidden and held in place with a plastic zip-tie.
I’ll report in the future if there are any problems with this set-up.
ID:	86418   Click image for larger version
ID:	86426   Click image for larger version
ID:	86434   Click image for larger version
ID:	86442   Click image for larger version
cyclejohn likes this.
Curtis is offline
