2015 Versys 650 ABS - Which Rox Risers Should I get? - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By fasteddiecopeman
post #1 of 14 (permalink) Old 11-06-2015, 11:08 AM Thread Starter
quexpress's Avatar
Smile 2015 Versys 650 ABS - Which Rox Risers Should I get?
Hi!
I intend on purchasing a set of 2-inch ROX Handle Bar Adjustable/Pivoting Risers for my 2015 Versys 650 ABS.
However since my Versys is in storage for the winter, I cannot examine the OEM riser to examine its anti-vibration rubber, etc.
Would getting the Rox anti-vibrations ones be an enhancement or overkill?
... or would the "regular" ones do the job (since the OEM ones are already rubber mounted)?
Any insight would be very appreciated.
Thanks!
Normand
I still have a full deck.
I just shuffle slower.
quexpress is offline
post #2 of 14 (permalink) Old 11-06-2015, 12:19 PM
I have a set of 2" ROX Risers w/out anti-vibe on my '15 650, and they work fine.
post #3 of 14 (permalink) Old 11-06-2015, 12:24 PM Thread Starter
quexpress's Avatar
That's good to hear.
I then take it for granted that the "extra rubber damping" would be overkill.
Thank you!
post #4 of 14 (permalink) Old 11-06-2015, 12:35 PM Thread Starter
quexpress's Avatar
I forgot to ask ...
Which model did you get?
I ask because Twisted Throttle does not show one for the 2015 Versys 650.
Would this one fit although the Versys is not listed on the page?
Rox Handlebar Risers For 22mm (7/8in) Bars Including Kawasaki KLR650, Honda XL650L, Suzuki DRZ400, DL650 V-Strom, DL1000 V-Strom, BMW F650GS, 1100GS, 1150GS, & Buell Ulysses | Black - TwistedThrottle.ca
Thank you
post #5 of 14 (permalink) Old 11-07-2015, 02:59 PM
Originally Posted by quexpress View Post
I forgot to ask ...
Thank you
I can't find a good pic just showing the riser, but you just need the 7/8" one, as that is the size of the handlebars on ALL of them. I had this riser on my '09 till it 'died'.... These pics will show it a bit.
post #6 of 14 (permalink) Old 11-07-2015, 03:09 PM Thread Starter
quexpress's Avatar
It is a 2-inch riser for 7/8-inch bars. I'll order it.
Thanks for the pics and insight Ed.
Much appreciated!
Normand
post #7 of 14 (permalink) Old 11-08-2015, 10:31 PM
BKKPhil's Avatar
Hi,
Just ordered a set for mine. Did you have to modify the cables or is there enough play on them?
BKKPhil is offline
post #8 of 14 (permalink) Old 11-09-2015, 10:36 AM
I have the regular risers, the anti-vibe one I received was a funny color and really stuck out. Also it wasn't solid (obviously) and I didn't like that feeling of extra play. I didn't install so I can't comment on the vibrations, but when I ride I don't feel a thing on the highway.
Modake is offline
post #9 of 14 (permalink) Old 11-09-2015, 08:30 PM Thread Starter
quexpress's Avatar
I ordered the "regular" one.
Thanks everyone! Much appreciated!
post #10 of 14 (permalink) Old 11-10-2015, 02:31 AM
Beezerboy's Avatar
so.... do you have to change the brake & clutch lines?
Beezerboy is offline
post #11 of 14 (permalink) Old 11-10-2015, 04:29 PM
Originally Posted by BKKPhil View Post
Hi,
Nope. Stockers are A-OK!
post #12 of 14 (permalink) Old 11-10-2015, 04:38 PM Thread Starter
quexpress's Avatar
That's great! Thanks!
post #13 of 14 (permalink) Old 09-22-2017, 10:09 AM
RoaringTodd's Avatar
How did you tighten the top two bolts directly under the risers?
RoaringTodd is offline
post #14 of 14 (permalink) Old 09-22-2017, 12:38 PM
The MANUAL for both the Gen 1 and 3 (650) indicates that you "snug" those two (18'/# torque) w/ the other two 'loose', then move the risers/ bars to where you want them, then tighten and torque the other two bolts to 18'/# also.
So as you do this, you'll have the fronts tightened and a "gap" at the rear of the 'holder' UNTIL you torque them.
RoaringTodd likes this.
