2015 versys Rigid led lights mounted - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 04-26-2015, 02:54 AM Thread Starter
Led mounted half Kawasaki brackets , half I made to copy the oem bar.
oem bracket
Motojunkee is offline
post #2 of 7 (permalink) Old 04-26-2015, 02:57 AM Thread Starter
My bracket that mimics the OEM one
painted ready to mount
post #3 of 7 (permalink) Old 04-26-2015, 08:05 AM
Nice!! Looks great!
HondaGalToo is offline
post #4 of 7 (permalink) Old 04-26-2015, 08:27 AM
Looks good. Personally, I would have gone with skenedesigns Amber LEDs for the lowers to provide additional turn signal lights since the uppers might get washed out behind those bright lights.
I need to find the time to take a welding class at the adult education center.
post #5 of 7 (permalink) Old 04-26-2015, 11:18 AM Thread Starter
I am not to worried about the turn signals. The upper led are only for night time back roads. Too bright for.the city. I have thought a few people the basics of welding then they took it from there. I learned from my father the basics with stick welder then bought a nice miller portable mig welder 110 volt it's for smallgauge metal only. The reason went this route due to not have to worry about buying garbage and fixing every year. I have had this unit now over 10 years trouble free can say that about my friends welders. With Flux core wire it can weld 3/16 inch steel in a single pass. My next welder will be a tig so I can do stainless and aluminum
post #6 of 7 (permalink) Old 04-26-2015, 11:55 AM
kawdog's Avatar
If the lower lights are attached to bottom fork leg, won't all that bouncing significantly shorten those bulbs' life? I don't feel it, but my wheel bounces crazy depending on the surface it's going over. I've never seen any mounted on a USD fork like that.
kawdog is offline
post #7 of 7 (permalink) Old 05-02-2015, 05:08 PM
Looks really nice MJ. Did you have to remove the fairing to install the bar?
Squishman is offline
