Radiator Guard Airflow - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 04-17-2015, 07:33 AM Thread Starter
jmarleau's Avatar
Deleted
jmarleau is offline
post #2 of 12 (permalink) Old 04-17-2015, 07:34 AM
Personally I doubt that will flow enough air, This is my RadGuard
post #3 of 12 (permalink) Old 04-17-2015, 08:07 AM
FWIW I have the Cox radiator guard on my Versys. No issues of air flow, nor were there issues on the last two bikes on which I'd installed Cox brand.
HondaGalToo is offline
post #4 of 12 (permalink) Old 04-17-2015, 08:38 AM
Rick's Avatar
Not saying that what you made won't work but, you still have a lot of real estate blocking airflow. If you look at the quality aftermarket products, they provide protection, without sacrificing cooling. Here's what I have on mine: EvoTech (look at how much "empty" space there is to flow air, with the holes being so close together, compared to your current set up).
2012 Versys
2007 Honda VTX 1800C
Sold everything else
Rick is offline
post #5 of 12 (permalink) Old 04-17-2015, 09:18 AM
Stud Muffin's Avatar
If you have the time, you could make the existing holes a little bigger. I think it looks better than the store bought ones by a mile. Nice work. Also you could use something to hold the grill off the rad by another 1/2" (washers, high temp rubber grommet,..) and get some flow around it as well.
Stud Muffin is offline
post #6 of 12 (permalink) Old 04-17-2015, 09:28 AM
id be really worried about overheating with that on...
post #7 of 12 (permalink) Old 04-17-2015, 01:51 PM
protecting the fan...
To protect my fan, I added some aluminum and some SS bite to my rad supports. Here's for the lower
and the lower front
and installed
post #8 of 12 (permalink) Old 04-18-2015, 07:03 PM
And here's what I did for the top:
and a pic thru the forks of the whole shebang!
post #9 of 12 (permalink) Old 04-21-2015, 03:07 PM
that looks far better to me my guard has mostly just stopped some big bugs from splattering on my rad....
post #10 of 12 (permalink) Old 04-23-2015, 08:46 AM
Originally Posted by jmarleau View Post
Nicely done JD.
Ditto!
post #11 of 12 (permalink) Old 04-23-2015, 11:55 AM
Mine ain't as pretty as jdrocks', but I also added one to the lower portion
as well as on top
and here's a view showing it all, thru the forks....
post #12 of 12 (permalink) Old 05-05-2015, 04:52 PM
...I just can't see how you can install these lines in "right side up" position without the lines looking like licorice.
Here's how I did mine, also on an '08, but notice my master cylinder - it's from an '09, for MUCH better brakes!
I'm pretty sure that, besides getting a bit stiff......, crashing onto my right-side won't damage the brake lines.
ALSO - my 'low' front fender has been raised about 1.3".
