happiness is 3 teeth.......... - Kawasaki Versys Forum
post #1 of 44 (permalink) Old 04-25-2009, 05:39 PM Thread Starter
scooter650's Avatar
I was reading about the hassles of changing out the front sprocket so I went about curing the speedo error problem by changing out the rear instead. Before the change, my speedo was out (read fast) by about 9% and after a 3 tooth reduction 46 >43, it is spot on (according to GPS). No need to shorten the chain and/or special tools, just take off the rear wheel (one nut) and spin off six nuts on the sprocket, replace sprocket , do up the same 7 nuts , adjust the chain and we're done!!! no need for pictures.......lol
scooter650 is offline
post #2 of 44 (permalink) Old 04-25-2009, 08:19 PM
oldkawboy's Avatar
Did you find a steel rear sprocket or is it aluminum?
When you get a chance would you please let me know how many rpm's you're now turning at 70mph?
I'm at 5,000rpm at that speed and would like to spin it a tad less but still have good grunt.
Thanks,
Dan
oldkawboy is offline
post #3 of 44 (permalink) Old 04-25-2009, 10:36 PM
Post
Nice Scoot...You gotta a part # and supplier....Many Thanks...D
contractor is offline
post #4 of 44 (permalink) Old 04-26-2009, 12:32 AM Thread Starter
scooter650's Avatar
details rr sprkt
The sprocket I used is a Vortex 452AK-43 ....A= aluminum and K= black
JT also makes them to fit in Steel: # 478 -43 see their web page here:
http://www.jtsprockets.com/52.0.html...el_uid=1138&p=
post #5 of 44 (permalink) Old 04-26-2009, 12:53 AM
Kimpex (Canada) sells "R.O.C." rear steel sprockets in 39, 40, 41, 42, 43, 44, 45, 46 and 47 tooth, as listed for EX560-A Ninja 650R. They're thinner at the core, and a bit lighter than stock... 15/43 is 6.98% taller than stock 15/46 sprockets, and 16/46 is 6.67% taller than stock. I found the 16/46 to be a bit too tall last year, so I just installed a 45 rear ROC with stock 15 front sprocket, for a resulting ~5% taller than stock, with taller 150/70 TrailAttack rear, close to 15/44 (+4.55%) with stock 150/60 rear.
Scooter650- You now have to add about 6% to your odometer and trip meter to get actual mileage... Can your GPS track the actual distance covered, or just in a straight line between two points?
post #6 of 44 (permalink) Old 04-26-2009, 06:35 AM
oldkawboy's Avatar
Good info..........thanks guys,
Dan
post #7 of 44 (permalink) Old 04-26-2009, 07:23 AM
Xo0oM's Avatar
The problem with aluminum sprockets is that they wear very fast. I had a vortex black aluminum sprocket on my ZX6R and it only last about 6000-7000 miles.
Xo0oM is offline
post #8 of 44 (permalink) Old 04-26-2009, 08:14 AM
MackDaddy's Avatar
MackDaddy is offline
post #9 of 44 (permalink) Old 04-26-2009, 12:02 PM
gti20vturbo's Avatar
My GPS is always on my bikes so I use the speed on it if for some reason an accurate reading it needed. Yes a GPS will cover distance traveled not straight line distance. Good to know it can be corrected but did you notice any performance hit?
ST1300, Versys, SV650S
gti20vturbo is offline
post #10 of 44 (permalink) Old 04-26-2009, 03:09 PM Thread Starter
scooter650's Avatar
actual mileage should now be correct........
With the sprocket change, the speedo is now acurate,IMO if anything, the mileage put on so far is over by 6% and is now reading accurate. Both speedo and odo use the same sensor as far as I know......
as far as performance, I like it a little better since there's less shifting around town.
post #11 of 44 (permalink) Old 04-26-2009, 08:51 PM
Your speedometer is now accurate. Your odometer and trip meter which were accurate with stock sprockets, are now under actual mileage covered by about 6%. You just need to add 6% to your indicated trip mileage, to get actual mileage. Mileage accumulated on the odometer up to when rear sprocket was changed, is pretty accurate. From now on, odometer logs about 6% less than actual mileage covered.
post #12 of 44 (permalink) Old 04-27-2009, 09:27 AM
tomla's Avatar
5-335645 sprocket for 45T. buy one now and get a free countershaft sprocket.
Sunstar triple-works hard ano aluminum.
same part # as the ninja 650R
tomla is offline
post #13 of 44 (permalink) Old 04-30-2009, 08:01 AM
texrider's Avatar
Waited a few weeks for the 44t Vortex, which turned out to be for .530 chain
Just ordered a steel 43t, since so many of you seem to like the 2.8 ratio.
I'm more willing to try it with the rear 43, rather than using a front 16.
Probably another week or two, now....
texrider is offline
post #14 of 44 (permalink) Old 04-30-2009, 09:22 AM
MackDaddy's Avatar
I finally got around to installing my SunStar steel 43T rear sprocket earlier this week. No riding yet other than around the neighborhood a few laps. We shall see.
All I'm looking for is a less hyper engine speed at 65-70 MPH (I've got a nice long trip coming up that includes 600 miles of superslab.)
post #15 of 44 (permalink) Old 04-30-2009, 10:22 PM
oldkawboy's Avatar
Went through our old sprocket box and found several rears from my youngest sons ZX6RR, everything from 39 to 46. After some experimenting I've settled on a 44 and it's the berries.
A tad slower off idle but will still wheelie even with the taller gearing and slightly longer wheelbase! :-)
It is more relaxed in high gear and that's what I was looking for.
I was gonna go with a rear steel but since these were used for dragracing they had very little wear and the Vortex brand looks great.........and they're free!
Dan
post #16 of 44 (permalink) Old 05-01-2009, 06:59 AM
furley's Avatar
Here's a noob question, why change the front if you can change the rear and achieve the same result? What is the difference between 16/46 vs. 15/43 (as far as ridability)? Previously, I've read posts about how riders like the 16T front, if changing to a 43T rear is easier then why change the front (other than it gets you in the garage longer and away from the wife and kids)
________
Digital Vaporizer
furley is offline
post #17 of 44 (permalink) Old 05-01-2009, 08:49 AM
Two thoughts:
1) A rear sprocket can cost a little more.
2) A smaller rear sprocket would use up some of the chain adjustment (moves the wheel to the rear a bit. This may not be an issue if you end up with adjustment left when your chain and sprockets are worn out.
I have stock gearing. The only times that I've noticed high rpms in 6th gear, I've also noticed that I was exceeding the speed limit by about 30 mph.
trialsguy is offline
post #18 of 44 (permalink) Old 05-01-2009, 03:51 PM
I prefer going to a larger front sprocket because it will be quieter and sprocket life will increase. Anything smaller than 15T with a 5/8" pitch chain is really a no-no. When chain wraps around a sprocket, it forms a polygon, and not a circle. The less angularity between adjacent links, the smoother the drive and the less wear on the chain and sprocket.
ttpete is offline
post #19 of 44 (permalink) Old 05-01-2009, 03:58 PM
My offroad motorcycle (GasGas 280) has the stock 12 tooth countershaft sprocket and a 1/2" pitch chain. Most guys I ride with have replaced theirs with an 11 tooth! The chains seem to hold up fine for a dirt bike. Given that we ride in dirt and mud all the time we don't get near as many miles on a chain as a street bike.
post #20 of 44 (permalink) Old 05-01-2009, 07:04 PM
amir_zwara's Avatar
I'm think I'm gonna swap my rear out for the 43 soon... whats a good sprocket to go with?
In terms of price and reliability...
amir_zwara is offline
