Step-By-Step Install for Motech Bars? - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 04-21-2013, 09:04 AM Thread Starter
Bars arrived yesterday. All the parts are there. Instructions are every bit as bad as I was warned they were. Are there step-by-step instructions anywhere for the average Joe that will tell me how to install these?
I'm picking up a 15mm socket, which I apparantly need for the nut on the main lower engine bolt, and some locktight today. I already have a tourque wrench.
Murph is offline
post #2 of 5 (permalink) Old 04-21-2013, 09:51 AM
I installed them myself, just followed the enclosed instructions. It is important though that you have the right tools. I have a 60 pc stanley ratchet set. If I remember correctly, there are 3 connections-one towards the front which you will have to take the original bolt off, use the bar's with a spacer. Next is the U bolt to be attached to the frame. Note to use the plastic protector between the frame and u bolt. Lastly, and this is not too difficult, but this is where the 2 bars are connected. There is a long bolt going from one side to the other, you need to remove this and replace it with the one with the bars.
IMPORTANT: MAKE SURE THAT YOU ATTACH THE FRONT END OF THE BOTH BARS FIRST LOOSELY SO THERE'S ENOUGH PLAY TO ATTACH THE U BOLT AND THE LONG ROD AT THE BACK END OF THE BARS.
Hope this helps! Good luck, enjoy and ride safely.
ESE_VERSYS2013 is offline
post #3 of 5 (permalink) Old 04-21-2013, 12:59 PM
When I installed mine (TWO sets), I found the LONG, lower rear bar VERY difficult to install as per their instructions, so I reversed it (NOW the nut is on the LEFT side). It's a question of fitting the spacers in limited (at least for MY fingers...) space while fitting that bolt. Here's 2 pics.
post #4 of 5 (permalink) Old 04-22-2013, 07:58 AM Thread Starter
Got them installed yesterday, with a little help from friends.
Murph is offline
post #5 of 5 (permalink) Old 04-23-2013, 01:26 AM
No trouble installing mine the normal way
