I've got the power - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 10-19-2011, 05:06 PM Thread Starter
if6was9's Avatar
I've got the power
Since I've owned my V, a much needed power plug has been absent. Taking advantage of a cold rainy day, I finally got around to adding such an item. Now I can plug in my heated face shield or clothing when the temps drop.
Easy install. I have it wired to a small fuse block under the other side of 'dash'.
"I read somewhere that 77 per cent of all the mentally ill live in poverty. Actually, I'm more intrigued by the 23 per cent who are apparently doing quite well for themselves." -- Jerry Garcia
if6was9 is offline
post #2 of 6 (permalink) Old 10-19-2011, 10:55 PM
2daMax's Avatar
Nice setup. What did you use to drill out the hole?
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #3 of 6 (permalink) Old 10-20-2011, 01:35 PM Thread Starter
if6was9's Avatar
I started off with a 1/8" pilot hole, then stepped up to 1/2". Then I used my trusty Dremmel with a drum sanding wheel, to enlarge the hole a tad over 3/4". It took some time, but the end result was worth it.
if6was9 is offline
post #4 of 6 (permalink) Old 10-20-2011, 09:53 PM
Nice set up. Thanks for sharing.
post #5 of 6 (permalink) Old 10-21-2011, 10:39 AM
emdavis197's Avatar
+1 on using the Dremmel. You could invest in a step bit, but don't be intimidated by cutting it yourself with a Dremmel drum sander. Just go slow, test fit the outlet often, and it is a piece of cake.
2009 Kawasaki Versys - Candy Plasma Blue
2013 Yamaha WR250R
emdavis197 is offline
post #6 of 6 (permalink) Old 10-21-2011, 11:16 AM Thread Starter
if6was9's Avatar
I thought about using my step drill, but by the time I remembered where it was...
if6was9 is offline
