44 t rear is done - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 11-28-2010, 09:32 AM Thread Starter
44 t rear is done
I went with the 44 t rear and i have to say i'm very happy with the results. I was going to go with the front 16 but from what i have read on this forum the rear is the easy way togo.. took me 10 min ... As far as the speedo its now only off by 2 mph not 6 as with the stock... now it 80mph indicated is 78 on my gps... i can live with that....now i can ride all day at a true 80mph just on the edge of 6,000 rpm that were i like it .... the power is the same as far i'm concerned....
woodsplitter is offline
post #2 of 13 (permalink) Old 11-28-2010, 10:05 AM
Good looking sprocket!!
post #3 of 13 (permalink) Old 11-28-2010, 11:42 AM
Good looking sprocket. Did mine about 2 weeks ago and the V is a different machine now.
Go enjoy the ride.
post #4 of 13 (permalink) Old 11-28-2010, 07:28 PM
jsquared's Avatar
What kind of mileage do you guys have? Did you just change out the sprocket, or the whole drive train(Fastoman)? I currently have just under 11,000 on mine, but the sprockets and chain are showing very minimal wear. Should i just wait until the whole thing needs to be replaced?
What say you?
Jsquared
Rider of all things 2 wheeled
jsquared is offline
post #5 of 13 (permalink) Old 11-28-2010, 07:50 PM
I want to do the same thing but my chain seems to have uneven stretch marks in it so I figure it's best to replace the whole drive system.
rumbo75 is offline
post #6 of 13 (permalink) Old 11-28-2010, 10:08 PM
siyeh's Avatar
I had 18000 miles on my V when I went to the 44 rear. My OEM chain was still within the stretch limits but was making noise. I changed all 3. Very happy with the 44 and a new OEM front. Put on a DID Gold X ring chain.
Should be good for another 18000 I hope,,,,
siyeh is offline
post #7 of 13 (permalink) Old 11-29-2010, 12:12 PM
csa714's Avatar
Hi Guys -
I have some mechanical experience, but would be considered a novice several times over relative to some of the guys on this site....for some reason taking off the tires scares me. Is it really that easy? Any special tools? I know this sounds silly, but is the circumference of the 44t the same as the OEM? (and therefore no chain change needed).
Foo Fighter Rider
csa714 is offline
post #8 of 13 (permalink) Old 11-29-2010, 12:51 PM
rponiarski's Avatar
I went with the 44 rear Renthal alloy one when I changed chains about 6,000 miles ago and I agree, it changes the whole feel of the bike. Probably the best change I've ever done. Power seems smoother, first gear is useable and I think my mileage hasn't suffered too much with me being in the 5,000 rpm and up range more. Now if I could only get about 20 more hp...
Richard M. Poniarski
'09 Kawasaki Versys
AMA#: 674623
ROK #: 100024905
rponiarski is offline
post #9 of 13 (permalink) Old 11-29-2010, 04:51 PM
Originally Posted by csa714 View Post
Hi Guys -
It works fine with the original chain. The axle moves back, but there's still enough adjustment left.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #10 of 13 (permalink) Old 11-29-2010, 05:22 PM
cls
Yep. I've done a 44T and a 16T. Both went fine w/the original chain.
cls is offline
post #11 of 13 (permalink) Old 11-30-2010, 10:58 AM
Lours_Polaire's Avatar
Hi Guys -
...I know this sounds silly, but is the circumference of the 44t the same as the OEM? (and therefore no chain change needed).
No !
A certain amount of teeth have a specific diameter since every "cog" have the same geometry/dimension
More teeth, bigger diameter
Less, smaller
LOP
Lours_Polaire is offline
post #12 of 13 (permalink) Old 11-30-2010, 01:30 PM
Pretbek's Avatar
I'm trying to avoid paying full shipping to 2 different places to get the parts that I need.
Do you guys know of a single vendor that has all of these:
- Steel 44T rear sprocket
- Rubber dampened 15T front sprocket (like OEM)
- Brand (DID, RKA, etc.) 520 chain
- bonus: Chain breaker/riveter tool
I went to sprocketcenter where I can get the Steel rear and the chain, but not the OEM-like front with rubber damping.
Pretbek is offline
post #13 of 13 (permalink) Old 11-30-2010, 02:04 PM
Try Bike Bandit. They have OEM as well as aftermarket parts. 10% discount to AMA members, too!
09 Versys
00 KLR
USN 1959-65
ttpete is offline
