2009 Versys electrical outlet install - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 06-15-2016, 10:00 PM Thread Starter
Gents,
I'm guessing that this isn't too difficult of a project, but I am absolutely clueless when it comes to electrical. I am looking to install a 12v socket into the dash on my 2009 Versys, but have no idea what kit I should be looking for, or how to install it. Some questions:
1) any recommendation for kits/components to make this easy (the 2009 Versys isn't wired for accessories)?
2) is it recommended to set up the socket to remain "hot" even when the bike isn't running? If so, how do I do this?
I've found quite a bit of info in the forum, but I'm too novice to know what applies to the Gen 1 Versys and what doesn't. Thanks in advance!
CA1234321 is offline
post #2 of 13 (permalink) Old 06-15-2016, 10:28 PM
i have a write up of my installing a cheap switch fuse block to my 08 (same as 09) i dont like thinks to be always hot (thought of a place to short out and or drain the battery) but if you wanna do it hot just hook it right to the battery and add an inline fuse and your done
post #3 of 13 (permalink) Old 06-16-2016, 10:47 AM
bigaussie's Avatar
Hi
I have my accessories wired via a Fuze-Block under my left fairing.
Depending on where you put your fuse it can be hot or controlled by the key.
bigaussie is offline
post #4 of 13 (permalink) Old 06-16-2016, 11:09 AM
Sounds like you have a spot to connect the 12V plug into if you have a fuse block. Usually one or two of the slots on one end or the other are hot. I used to keep mine hot since that is where I plugged in my trickle charger. No I have a separate wire for the battery charger that is in one of the hot slots, so I keep my 12V plug on a cold line. I've never installed mine, just keep it hanging by wire by the front left faring, and sealed with a cork. I'm getting ready to replace it with a double USB plug, and I will cut a hole and install that on the left side of the dash.
rayj
2009 Versys (Mine's Green)
rayj is offline
post #5 of 13 (permalink) Old 06-16-2016, 10:59 PM Thread Starter
Thanks,
Where can I find your write up? I searched for it through the forum to no avail.
post #6 of 13 (permalink) Old 06-16-2016, 11:01 PM Thread Starter
I'll have to look, but I don't believe I have a fuse box. I don't believe the first generation bikes have them.
post #7 of 13 (permalink) Old 06-16-2016, 11:16 PM
bigaussie's Avatar
I have both.
Here is a link to a really good double USB
post #8 of 13 (permalink) Old 06-16-2016, 11:17 PM
bigaussie's Avatar
Correct - that is why I added a Fuze-Block
post #9 of 13 (permalink) Old 06-16-2016, 11:48 PM
No need to cut the dash.12V Outlet / USB with an on/off switch...https://www.amazon.com/EKLIPES-EK1-1...36T216MD8WB85S
ďThe difference between genius and stupidity is that genius has its limits.Ē Ė Albert Einstein
post #10 of 13 (permalink) Old 06-17-2016, 01:09 AM
bigaussie's Avatar
And lower on that page is a link to a cig & 2 USB
Too bad I didn't know of these several years ago. I put the 12 volt on in 2010 & the USB's in 2012.
post #11 of 13 (permalink) Old 06-17-2016, 09:36 AM
Thanks,
http://www.kawasakiversys.com/forums...ects-come.html
post #12 of 13 (permalink) Old 06-17-2016, 05:01 PM Thread Starter
Haha...Thanks, I appreciate the post!
post #13 of 13 (permalink) Old 06-18-2016, 10:41 AM
Sounds like you have a spot to connect the 12V plug into if you have a fuse block....
Bigaussie, I was thinking you had posted the original message. I've got to start paying more attention, or, start drinking more and writing and riding less.
For CA1234123 re: a spot for fuze block, I have attached a pic of the Eastern Beaver block I got from an expat American who lives in Japan and makes quality stuff. The one I have has 2 hot slots and 6 cold (ignition on only) slots.
rayj
rayj is offline
