Oil Pressure Switch - Kawasaki Versys Forum
post #1 of 2 (permalink) Old 07-19-2010, 12:30 PM Thread Starter
Oil Pressure Switch
What is the procedure to clean or swap out an oil pressure switch on a Versys? Is is a 5 min job and can it be done when these is oil in the engine?
Jim
09 Kawasaki Versys - Green
07 Kawasaki KLR 650 - Black
jharrissocal is offline
post #2 of 2 (permalink) Old 07-19-2010, 02:29 PM
Hi,
I have got a service manual. In the chapter 7-16 is the following:
Drain the engine oil
Remove:
Right Lower Fairing
Switch Cover
Switch Terminal Bolt
Oil Pressure Switch
Oil Pressure Switch Installation
Apply silicone sealant to the threads of the oil pressure
switch and tighten it.
Sealant - Kawasaki Bond (Silicone Sealant): 56019-120
Torque - Oil Pressure Switch: 15 Nm (1.5 kgfm, 11 ftlb)
Install the switch lead direction downward.
Apply grease to the terminal, and tighten the terminal
bolt securely.
NOTE
Apply a small amount grease to the terminal so that
grease should not close two breather holes [A] for
switch diaphragm.
I think it is not too difficult procedure.
Mollacsek is offline
